Old 12-15-2025, 03:22 PM   #1
prateroad
71 Horn contact, bewildered?
I have tried 3 different cancelling cams and can't get power through spring loaded pin that comes up through it. I put a test light on all of them and have power to brass ring but nothing up to the pin. I'm baffled, TIA.
prateroad is offline   Reply With Quote
Old 12-15-2025, 03:51 PM   #2
pjmoreland
pjmoreland's Avatar
Re: 71 Horn contact, bewildered?
I've run into that issue before. It was caused by oxidation where the spring touches the metal plunger. The plunger can be pulled out by tugging on it firmly to dislodge the red locking ring. Then you can clean up the ends of the spring and the surfaces that the spring touches with some fine sand paper. You might also want to try just spinning the plunger a bunch to see if you can get the spring to scrape through the oxidation without taking anything apart.
pjmoreland is offline   Reply With Quote
Old 12-15-2025, 04:01 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
It provides a ground.
Three wires at the horn relay.
Green- Provides the hot to the Horn
Red- Hot setting at the Relay
Black- Ground from the column
Smitty
71 C10 283/3SPD Full Resto
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me https://67-72chevytrucks.com/vboard/...d.php?t=841215
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
