01-19-2004, 10:58 AM | #1 |
Sell it before it's finished
door differences?
Can someone explain the differences between 67-71 and 72 doors.
01-19-2004, 11:08 AM | #2 |
Resident Curmudgeon
2 main differences:
1. In 72, the flat steel inner door panel was nixed for a moulded plastic one. This one uses clips to attach it rather than screws. The contours of this panel requitred longer shafts on the inner door release and the window regulator handles. 2. After years of cracked doors, GM finally re-enforced the area where the wing vent post entered the innder door shell by installing a screw to hold the inner and outer door skins together at that point. They found out that had use on the wing vent cuased stress in this area. Neither of these issues should prevent door interchangeability as long as you have the matching "guts" for the door panel and strict adherence to stock is not an issue. Any year door will bolt onto any year cab.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
01-19-2004, 11:16 AM | #3 |
Thank you for the quick and informative reponse.
Brian |
01-19-2004, 03:10 PM | #4 |
I also noticed a difference in the door handle mount on my 67' doors. The repro handles don't mount on my door. My door has a bracket welded on the inside of the outter skin that makes the mounting bolts enter the door handle horizontal. The bracket is kinda "L" shaped. I had to have my original handles rechromed to get a proper fit on the door.
Mike 67' GMC Fleetside |
