Old 01-01-2026, 02:23 PM   #1
farmall
farmall's Avatar
Wiper motor is weak.
89K5 Multi speed motor is slow on start up and has difficulty moving even light snow. It works OK on constant speed low but highest speed is not much faster. Are they serviceable?
Thanks.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 01-13-2026, 12:00 PM   #2
65chevysub
65chevysub's Avatar
Re: Wiper motor is weak.
The motor on my 84 Sierra is the same. I asked on the gmsquarebody forum if I could take it apart and clean out the original grease as I think that's the problem. Both speeds on mine are the same:Slow! It was recommended to lube to linkage as well
65chevysub is offline   Reply With Quote
Old 01-21-2026, 02:34 PM   #3
chris989
Thanks.
Mine was the same, 89 v2500. I replaced with a new motor and it is a 100% improvement. I forget where i bought it,
I did not mess with relays/wire or dig into the cowl for lubricating the linkage.
chris989 is offline   Reply With Quote
Old 01-22-2026, 08:54 AM   #4
chrismoore701
chrismoore701's Avatar
IF you pull apart and regrease, be sure to look into low temp grease
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
