Old 01-06-2026, 11:34 AM   #1
kglowacky
hard starting
My LS1 2002 has a hard time 1st starting for the day. Turn key on, let fuel pump run then try to start. It will crank and crank start to spit and flutter then will start after 20 seconds then the rest of day it runs good until yesterday. went to store came out won't start. Crank crank flutter spit but won't start. Towed home. 5 hrs later crank crank sputter sputter then it started. Thinking fuel problem filter or pump. any sensors I need to consider
Thoughts
kglowacky is offline   Reply With Quote
Old 01-06-2026, 10:34 PM   #2
LS short box
Re: hard starting
Does the fuel pump cycle like it should when you turn the key to start?
Have you checked the fuel pressure. Oreilly's will "loan" you pressure tester that you can attach to the fuel rail. Should be about 58 psi when running.
LS swaps love/need good grounds. Main neg cable from the battery directly to the engine block.
The ECM 12 volt constant should be directly from the battery.
LS short box is offline   Reply With Quote
Old 01-07-2026, 11:07 AM   #3
kglowacky
Re: hard starting
fuel pump I can hear cycling when key is turned on but I think I didn't hear it yesterday at first. and it did start up after cranking it a few times. Will check fuel pressure next.
Old 01-07-2026, 12:47 PM   #4
TrybalRage
Re: hard starting
I would check not only the pressure but what the pressure is after sitting. If the system is "bleeding down" when not running then you've got really low pressure at start up.
1985 C10 Silverado LWB LS Swapped! Other Stuff
2010 Suburban 2500 LT 4WD
YouTube
TrybalRage is offline   Reply With Quote
Old 01-07-2026, 09:51 PM   #5
kglowacky
Re: hard starting
Good point
Old 01-08-2026, 02:05 AM   #6
leegreen
Re: hard starting
+1 for check fuel pressure
have you scanned for codes?
leegreen is offline   Reply With Quote
Old 01-08-2026, 08:33 AM   #7
biketopia
Re: hard starting
Another suggestion for checking fuel pressure. How is your pressure regulated? Dedicated regulator, factory rail-mounted, C-5 style fuel filter?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 01-08-2026, 11:35 AM   #8
kglowacky
Re: hard starting
C-5 style corvette filter
Old 01-08-2026, 12:17 PM   #9
AussieinNC
Moderator
AussieinNC's Avatar
Re: hard starting
Check fuel pump relay
Check main ground battery to engine and tow grounds at rear of block
Check fuel pressure leak down
Check crank sensor
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2025 Chevy Equinox
AussieinNC is offline   Reply With Quote
