Old 01-12-2026, 01:15 PM   #1
JQ-72
JQ-72's Avatar
K20 rear brake line help
Having trouble locating the correct rear rubber brake line on my 1972 K20. I’ve had guys at the parts house look up 72 K20, 72 C20, 73 C30, even some stuff up in the 80s. Everything they pull off the shelf has the smaller female ends on the distribution block - like a 1/2 ton would have. Anyone bought the correct one that I can get the part number from? Thanks
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
Old 01-12-2026, 01:34 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: K20 rear brake line help
What size lines are you needing? Everything I remember messing with is 3/16 lines from the soft line fitting to the wheel cylinders. Are you trying to get 1/4” all the way to the wheel cylinders? I don’t think there’s a difference in line diameter between 1/2 and 3/4 ton or even the K30 stuff but I’ve been wrong before. Even my 1998 K2500HD has 3/16 lines across the rear axle.
Tyler
57taskforce is online now   Reply With Quote
Old 01-13-2026, 01:58 PM   #3
JQ-72
JQ-72's Avatar
All 3 holes are 7/16”
Old 01-13-2026, 03:28 PM   #4
HO455
HO455's Avatar
QI used NAPA 36683 for my coil spring Burban with a 71-72 rear axle. I'm not sure but I believe the leaf spring K model hose is longer. I believe mine was 20 inches long. It has 3 -1/4" female inverted flare connections.
RIP Bob Parks.
Old 01-13-2026, 07:44 PM   #5
JQ-72
JQ-72's Avatar
All 3 female ends the same size? Every one the parts store gives me has 7/16 from the frame and 3/8 on the block. Thanks
Old 01-13-2026, 07:49 PM   #6
HO455
HO455's Avatar
I recently replaced mine and the old one is still in the shop. I will go out tonight after work and verify the size of all three connections.
RIP Bob Parks.
Old 01-13-2026, 10:31 PM   #7
HO455
HO455's Avatar
All three connections are 7/16-24.
RIP Bob Parks.
Old 01-13-2026, 11:54 PM   #8
JQ-72
JQ-72's Avatar
Awesome! Thanks for much for taking time to look.
Old 01-14-2026, 09:35 AM   #9
HO455
HO455's Avatar
You're welcome! Just trying to help as many folks as I can. So many people here have helped me over the years. (I've got a long ways to till I break even. Thanks everyone! )
RIP Bob Parks.
Old 01-14-2026, 09:42 AM   #10
Jason Banks
Jason Banks's Avatar
On my 67 K20 front brake lines that has the HD front... There were no aftermarket brake hoses available. I had a local hydraulic shop duplicate the originals. They had to order fittings for one end.
So, if you have your old one, you may be able to get it duplicated.
Jason Banks is offline   Reply With Quote
Old 01-14-2026, 05:31 PM   #11
JQ-72
JQ-72's Avatar
We got some shops here that will make up hydraulic hoses and that would be my last option. I figured there had to be some reproduction ones made, just had to get a little help from the board!
