Accelerator pedal problem
Hi all. I’m doing a LQ4 swap into my 1979 GMC Camper Special. I just did a first start and it idled and ran pretty good. There is a problem I am fighting with and that is when I press the gas pedal the RPM increases a couple of hundred RPM and then drops back to idle. If I keep the gas pedal pressed it just keeps doing that and starts to run rough. Has anybody run into this problem and if so how did you solve it?
Thanks Eric |
| Bookmarks |
