Old 01-13-2026, 06:49 PM   #1
pringle85
New Member
pringle85's Avatar
Center AC Vent Issue
Life got in the way for a few years, but I am now back to reassembling my 70 GMC. I am working on putting interior parts back in the cab before setting it back on the frame. I've ran into an issue with my center AC vent. It was a factory AC truck, and I'm quite sure the vent is OEM. The issue is that my chrome vent is two pieces instead of just one. I'm guessing that I am missing some kind of clips that held the two pieces together, but don't have anything that looks like it would work. Can someone either tell or show me what I am missing? And more importantly are these available separately? Thanks for any help.
pringle85 is offline   Reply With Quote
Old 01-14-2026, 06:01 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Center AC Vent Issue
I will run out and take a look at one of mine. I think the plastic frame is just staked over the round pivots on each end.
EDIT: I went out and looked and it looks like there is a small piece of black plastic over the top of the pivots, and then the plastic is heat swedged over the top of those in four places.
Leon
Old 01-15-2026, 12:27 PM   #3
pringle85
New Member
pringle85's Avatar
Thanks for the picture and explanation. Guess I'll look for a replacement.
Old 01-15-2026, 01:39 PM   #4
truckster
truckster's Avatar
If you have a friend with a 3D printer, they should be able to make a couple of small parts for you in no time.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 01-15-2026, 02:47 PM   #5
Rust_never_sleeps
Rust_never_sleeps's Avatar
You could just drill a hole in the middle of a plastic rectangle. Cut it in half and you'll have both
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 01-15-2026, 11:15 PM   #6
Bob B.
Decent reproductions sell for around $30 if you can't fix your OEM one.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 01-16-2026, 01:40 PM   #7
pringle85
New Member
pringle85's Avatar
Thanks to all who responded. I am in the process of buying a used one from 72 tigger.
