Old 01-13-2026, 07:34 PM   #1
808_c10
Trailing arms
My truck came with leaf springs and I want to convert to trailing arms so I can drop on springs and later in the future, bags. I've read that i can use my existing rear crossmember, add the brackets, track bar, and shock mount crossmember.
Does this sound right?
Anyone got a source for old trailing arm takeoffs?
808_c10 is offline   Reply With Quote
Old 01-14-2026, 02:18 AM   #2
RustyPile
RustyPile's Avatar
Re: Trailing arms
Remove the existing spring pads on the rear-end housing.. New ones go on at angle. Don't forget to set pinion angle before welding.
RustyPile is offline   Reply With Quote
Old 01-14-2026, 01:32 PM   #3
SCOTI
SCOTI's Avatar
Re: Trailing arms
Truck arms are easy for doing the coil to bags swap for dropping. It's also pretty easy to get the same rear drop (as a dropped coil) w/the leaf set-up by simply doing a flip kit on the rear.
As far as used/take-off rear truck arms..... sites like this work well sourcing used parts, but you'll need to be a 'subscribing/supporting member' to place an ad for what you're trying to find.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-14-2026, 01:52 PM   #4
awryexperiment
Re: Trailing arms
I have one old trailing arm in perfectly good condition that I have not gotten around to selling.... but I'm in NJ.
1972 Chevy C-20, LWB, Fleet, 350, SM465 4-spd, dark olive green, stock, restored.
awryexperiment is offline   Reply With Quote
Old 01-14-2026, 08:40 PM   #5
mr48chev
mr48chev's Avatar
Re: Trailing arms
Classic parts has the axle seats that are cut at the right angles to use with trailing arms.
https://classicparts.com/chevy-gmc/t...ear-axle-seats
The good thing with them is that they will stick them in the smallest priority mail box they will fit in or will send you a bunch of small pieces in a priority mail box and that might help you quite a bit with shipping.
They do have tubular trailing arms but they aren't inexpensive. https://classicparts.com/chevy-gmc/t...lar-black-pair
Plus a number of different height rear coil springs.
Then you still need the U bolts, hardware to connect the trailing arms to the crossmember and a rear sway bar.
Personally, I would just flip the axle on top of the spring and forget the bags.
My ongoing truck projects:
Old 01-15-2026, 04:43 PM   #6
SCOTI
SCOTI's Avatar
Re: Trailing arms
I would not use a Truck Arm that's a solid tube construction (round or square) with fixed ends.
The originals were I-beam construction (allows for some flex/twist) w/rubber bushings @ the front end (also allows for some flex). Remove that 'flexibility' & you now have bind.
Tubular arms should have a flexible joint @ the leading end to allow for some non-binding rotation.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
