Old 01-14-2026, 04:25 PM   #1
Ziegelsteinfaust
Brakes
I believe my brake booster is bad as it wont release the brakes when I stab it hard when some idiot is on a suicide run.
What would cause this. Or is my diagnosis wrong and its the master cylinder?
Ziegelsteinfaust is offline   Reply With Quote
Old 01-14-2026, 06:27 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Brakes
I would suspect front brake hose(s).
They can collapse internally and trap pressure.
Or a corroded caliper/piston.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-16-2026, 11:28 AM   #3
Ziegelsteinfaust
Re: Brakes
I have no brake drag.
The issue only happens when the brakes are hit hard.
Old 01-18-2026, 02:29 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Brakes
Open a bleeder when it does it next.
If there is pressure your brake hose failed.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 01-19-2026, 02:12 AM   #5
leegreen
Re: Brakes
pop the vacuum line off booster next time, if that release break pressure there is an issue with booster
When they do lock on how do you release them?
leegreen is offline   Reply With Quote
Old 01-19-2026, 11:46 AM   #6
Ziegelsteinfaust
Re: Brakes
I had to replace my calipers due to a sticky one along with the hoses just because, amd the problem persists.
Old 01-19-2026, 11:47 AM   #7
Ziegelsteinfaust
Re: Brakes
I will try that next time. Unfortunately it doesn't happen when I try to recreate the issue.
I pull the pedal up with my toes.
Old 01-19-2026, 11:55 AM   #8
leegreen
Re: Brakes
sounds like the problem is most likely mechanical in the pedal, pushrod, return spring.
remove the two nuts holding master to booster, pull master away from booster and play with the pedal.
A c10 style pedal box, may need the pivot shaft removed, cleaned and lubed. That was sometimes an issue even when these trucks were newish
Old 01-24-2026, 12:41 PM   #9
karlbenz
Re: Brakes
bad booster usually makes for a hard pedal
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
1990 Chevy Bus 8.2l fuel pincher 8800 miles
1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO
karlbenz is offline   Reply With Quote
Old 01-24-2026, 05:27 PM   #10
RustyPile
RustyPile's Avatar
Re: Brakes
The pedal pushrod is not mechanically attached to the booster/Master cylinder. The rod only rests in a pocket in them.. If pulling up the pedal releases the brake, something - a bushing, linkage piece - is binding, thus preventing the pedal from returning.. You may have to remove the complete pedal assembly in order to make repairs.
RustyPile is offline   Reply With Quote
Old 01-27-2026, 02:36 AM   #11
Ziegelsteinfaust
Re: Brakes
I will pull the pedal this weekend and grease the unit. Plus deburr any rough spots
