Old 01-19-2004, 02:35 PM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
Panhard questions
A buddy of mine likes to make stuff rather than buy it. He wants to make a panhard bar for the truck he is building. He is considering using Schedule 80 3/8" black pipe, od is .675" and id is .423 and he is going to drill and tap for a 1/2" fine thread Heim joint. The Heim joints have 1/2" holes to affix to the axle tube and frame.
Anyone have thoughts on whether that setup is strong enough for a panhard bar?
Also, is there a specific angle he should try to have the panhard bar at?
The specific application is a 1965 Chevy C10 with a 1972 coil spring truck rearend.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-19-2004, 03:11 PM   #2
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Plastic or metal?
67Fleetsidedream is offline   Reply With Quote
Old 01-19-2004, 03:34 PM   #3
Slammed67
Progress = 0%
Slammed67's Avatar
Ideally it should be horizontal (no angle). This will provide the least amount of side to side travel.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 01-19-2004, 03:50 PM   #4
Low69CST
It should also be as long as possible
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 01-19-2004, 04:00 PM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
It is metal pipe.
Old 01-19-2004, 04:29 PM   #6
67Fleetsidedream
It should work. It may loosen up over time due to it being hollow.
Old 01-19-2004, 04:51 PM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
Are they normally solid?
Old 01-19-2004, 04:54 PM   #8
Low69CST
I bought one from ECE that is tube with threaded ends welded on
