AC/fan switch
So when I purchased my '72 C10 the previous owner told me to buy a switch because the switch would not operate when pushed all the way (high???) down.
From the top position (I'm assuming is off), one click down is low (works), second click is medium? That works, but when I push the switch all the way down where it says high I get nothing. I purchased the switch today, got it changed out and got the same results. Can anyone help? |
#2 | |
![]() Join Date: Dec 1999
Re: AC/fan switch
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#3 | |
Re: AC/fan switch
I will check tomorrow. If the fuse is good, the relay is located in the box next to the transmission hump correct? Also, only because I have not taken a look at the fuse block, does it say cigarette lighter on the fuse box? |
Re: AC/fan switch
I did find this pic of the fuse block, not sure if it's the same for my year.
https://67-72chevytrucks.com/vboard/...6&postcount=20 I do see a spot that says "cig." It doesn't look like a glass tube fuse goes there. |
Re: AC/fan switch
Relay here arrow A and view A. It is difficult to get to the attaching screws. A 1/4 drive ratchet with a short extension works. If you have another relay, plug that one in and try your switch BEFORE removing the old one.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks, a 5 speed AND a front hitch! |
Re: AC/fan switch
Ok so I took a look at the fuse box and there is nothing attached to the "cig" spot. That would explain why the cigarette lighter and "high" on the fan switch are not working correct?
What color wire should be attached there and would it be coming from the relay near the glovebox? |
Re: AC/fan switch
this is apparently a VERY common issue. My current '72 has an intermittent "no work" but it always goes when I back it off one level from high to medium then back to high. Also, way back in the last 80's my '72 GMC did the exact same thing, but was more prominent than my current truck.
'72 C10 Cheyenne SWB North Carolina kept for 50 years, 75k original miles, Medium/Hawaiian Blue paint, 3 owners - one for 40 years & garaged kept. Original: sheetmetal, undercarriage, moldings, glass, immaculate unrestored bed. * * * New - rebuilt engine at 65k in 2015, one frame-on respray in 2010, front bumper, blue houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
Re: AC/fan switch
Confused this post with another. Originally I assumed you have A/C. Do you? If not the relay will not be present. See this post as well concerning fan speed issues https://67-72chevytrucks.com/vboard/...d.php?t=862317
#9 | |
Re: AC/fan switch
I plan on looking for the relay and following the wire to see if it meets up with the wire from the lighter. Hopefully this will lead me to the promise land. I would assume at this point I don't need to worry about replacing the relay or resistor since there is nothing attached at the fuse box, correct? Last edited by r8rs4lf; 01-17-2026 at 09:02 AM. |
![]() Join Date: Apr 2016
Re: AC/fan switch
The relay is on the right side of the heater core box behind the glove box, very inconvenient to get to unless your glove box and/or heater core box happens to be out.
There is no CIG fuse, the CIG position on the fuse box is unfused always-on power. Normally a 12 gauge red wire connects there and that red wire goes to the cig lighter. The 12 gauge red wire has a piggy back connector on it that looks like this: There should be a 12 guage orange wire that will plug into the piggy back connector on the red wire. That goes to the high speed relay. Here is the wiring diagram for the A/C system showing the orange wire going to the relay. https://67-72chevytrucks.com/vboard/...d.php?t=844482 I can’t tell very well from your picture but I think the orange wire plugged into IGN UNFUSED with the piggy back connector on it is probably something smaller than 12 gauge and may be powering something else. I’m not sure about the 12 gauge red wire you have plugged into the ING UNFUSED because I don’t see a 12 gauge piggy back connector on it. So I’m thinking it probably isn’t the one for the cig lighter. I think it is likely the wire I point to with arrow 1 is the high speed relay 12 gauge wire, and arrow 2 the cig 12 gauge red wire piggy back, but can’t tell where they are plugged in or if they are plugged in, so I’m afraid it is just a guess. If that is not plugged in, it probably needs to be plugged into CIG position. Last edited by dmjlambert; 01-17-2026 at 02:07 PM. |
#11 | |
Re: AC/fan switch
#12 | |
Re: AC/fan switch
In picture two, you can see that there is a piggy back on that red (arrow #2) wire that has an orange AND a yellow wire. The yellow wire is not connected to anything, but the orange wire goes up in to a loom that heads towards the passenger side. Picture three is everything I said in one pic. Last edited by r8rs4lf; 01-17-2026 at 05:20 PM. |
#13 | |
![]() Join Date: Jun 2022
Re: AC/fan switch
It'll make you crazy until you can wrap your head around that.....or so I have heard ;-)
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
#14 |
Re: AC/fan switch
So while taking a peek under the dash I found that the cigarette lighter was replaced and the wires were tucked up under the dash as you can see in pic 2. There's only the green wire connected to the rear of the lighter. The red is a single wire that was just wrapped with the green wire. It's not connected to anything, a stand alone wire that looks like it just came with the lighter assembly.
Also in pic two below you can see a red single wire just hanging there. That was also just tucked up underneath. I tried to follow it to see if it goes to the fuse box, but I loose it as it goes up towards the gauges. Last edited by r8rs4lf; 01-17-2026 at 05:24 PM. |
#15 |
Re: AC/fan switch
OK so the cig lighter wire and its piggy back A/C high speed relay wire is plugged into GL BOX. There is a 15A fuse right below there and that is the fuse for that. It is OK to plug that in there, but fuse may be blown, you can change it to a 25A fuse so it can run the blower on high speed, or you can move that red 12 gauge wire and it's piggy back orange 12 gauge wire from the GL BOX position to the CIG position. The green wire you see is just for the light in the cig lighter. The bare stud sticking out the back of the cig lighter needs the 12 G red wire attached to it. That should get the cig lighter working.
Here is a pic and thread link to discussion of the fuse box so you know what powers what on the fuse box. Once you get the cig lighter working, you can trace that orange wire connected to the piggy back connector to the high speed relay and see if it is plugged into the high speed relay. |
#16 |
Re: AC/fan switch
Here is a top down view of the high speed relay from another discussion. Where the arrow is pointing is where a thinner 18 gauge orange wires should be plugged in; that thin wire comes from the blower speed switch. The 12 gauge orange wire you can see in the picture and that comes from the (normally CIG position) fuse panel.
That thread mentions another reason the high speed relay may not be coming on, the thin orange wire was not plugged in to the high speed relay. And finally the AIR COND fuse may be blown, there's another thing to check. Last edited by dmjlambert; 01-17-2026 at 05:38 PM. |
#17 | |
Re: AC/fan switch
#18 | |
Re: AC/fan switch
#19 | ||
Re: AC/fan switch
So you have some choices here. The aftermarket lighted cig lighter in your truck was not completely hooked up yet, and there is a red wire for it that has not been used yet. There is probably the factory red wire that is not plugged onto the post of the cig lighter that is probably stuffed up there somewhere behind the dash. You can use that one, or you can use the new red wire. I can't tell if the new red wire has a piggy back connector on it. If it does not, and the 12 gauge orange wire for the high speed relay also does not have a piggy back connector on it, you can plug those things into 2 separate positions on the fuse panel. The choices of places to plug stuff in are shown in the fuse panel picture, CIG is unfused always hot, IGN UNFUSED is hot in the key on position and is also unfused, and GL BOX is always on and fused usually with a 15 A fuse but if you plug something in it that draws a lot of power you may need to use a 20 A or 25 A fuse in the GL BOX position. |
#20 | |
Re: AC/fan switch
So assuming the orange 12 gauge wire is attached to the relay and the smaller 18 gauge wire is there as well, besides moving the plug with the two red wires from the glove box to cig, all I need to do is attach that red wire hanging to the lighter and that should get me HIGH on the fan switch correct? It's kind of funny understanding how all this works and just because someone didn't hook up the new cigarette lighter created this problem. My dad always taught me that if you are going to do something do it right the first time. Obviously this was not the case with whoever just mounted the lighter and not understand the consequence that came with it. I really appreciate your help and I will get under there and get it sorted out. Another quick question only because I haven't really looked upon there, I only put my phone up there, the stud on the back of the lighter, how does the wire hook up to that? Last edited by r8rs4lf; 01-17-2026 at 06:11 PM. |
#21 | |
Re: AC/fan switch
#22 |
Re: AC/fan switch
No problem. The wire hooks up to that stud by a push-on connector. That connector is not very much like any other connector on the truck, it is a female round connector. I'm afraid I don't remember what it looks like.
#23 | |
Re: AC/fan switch
So it sounds like you are saying that the position where those two red wires are plugged (glove box) in to is not hot meaning the relay is not getting power therefore no HIGH setting? |
#24 |
Re: AC/fan switch
I just went outside and moved the plug to the CIG position and I got HIGH to work. That's crazy, it just needed power besides (probably a blown fuse in the glove box position) the fact it was plugged in to the wrong place.
I also looked at the plug on the hanging red wire. I slid it onto the stud on the rear of the lighter, but it would not stay. The new red wire has that exact same plug on one end and the other end has the plug to attach to what looks like a male tab on the fuse box. It's all starting to come together!! What about the green wire, could I potentially plug that in to the yellow wire attached to the piggy back in my previous pics? One more thing, I saw a plug just hanging there and this box attached to the firewall that looks like it belongs there. What is that and does that plug belong on it? Last edited by r8rs4lf; 01-17-2026 at 06:53 PM. |
#25 | |
Re: AC/fan switch
| Bookmarks |
