Old 01-20-2026, 11:15 AM   #1
Longhorn 69
Junior Member
Need OEM Exhaust pipes for my 1969, 396 Longhorn
I am working on getting my exhaust for my 396 Longhorn and of course no one has it. I prefer not to get it made at a muffler shop. Talking with Waldron's if they had an old set of OEM exhaust pipes from a Longhorn, for a pattern they would be able to make the system for me. The 133" Longhorn wheelbase uses the same tail pipe sytem as the 127" wheel base trucks. So all I am looking for is the longer exhaust pipes for a pattern.
Greg
69 Longhorn 396, 4 Speed SM 465, PS, PB, No Air
Longhorn 69 is offline   Reply With Quote
Old 01-20-2026, 04:43 PM   #2
c30
Active Member
c30's Avatar
Re: Need OEM Exhaust pipes for my 1969, 396 Longhorn
Did you try Napa? They carry Walker products and can usually order any pipe they made.
c30 is offline   Reply With Quote
Old 01-20-2026, 11:44 PM   #3
Longhorn 69
Junior Member
yes I did, and they cannot get anything I need.
Greg
Old 01-21-2026, 07:16 AM   #4
Dave
DND Trucks
Not sure if they have exactly what your looking for but you might try Shafer Classic exhaust systems in OH. Probably not the cheapest however it appears to be as close to oem as you can get.
Dave is offline   Reply With Quote
Old 01-21-2026, 09:54 AM   #5
Longhorn 69
Junior Member
I took a look at Shafers, and they have a lot of systems but I could not find one for my Loghorn. What I'm trying to find is just a set of old used exhaust pipes that are good enough to use as a pattern to make a new set. The Longhorn exhaust pipes are 6" longer than the 8' Longbox 127" wheel base trucks. I am trying to find out where the extra 6" of pipe is added. It's to bad no one makes the complete system for the Longhorns. Thanks for the info Dave!
Greg
Old 01-21-2026, 08:20 PM   #6
Dave
DND Trucks
I wonder if the 6" inches would be just under the add on portion for the longhorn bed?
Old 01-21-2026, 09:58 PM   #7
Longhorn 69
Junior Member
Thats what I'm thinking but not sure. I'm thinking of buying the 127" system from Waldrons and figuring out where to add the 6" myself. should not be that difficult, Maybe! LOL. I think I have had bigger challenges!
Greg
Old 01-21-2026, 10:26 PM   #8
Dave
DND Trucks
I think your idea of adding the 6" to the 127 wheelbase is likely the best option.
Old 01-23-2026, 10:05 AM   #9
Longhorn 69
Junior Member
That's what I think also. It seems like it would most likely be in straight spot in that area.
Thanks for your thoughts Dave.
Greg
