Old 01-19-2004, 03:30 PM   #1
Low69CST
Problem with Power Disc Conversion
My truck came originally with non-power drums and i'm switching it to power discs. I got the bracket that bolts on the firewall with the pivots that hooks to the booster. The problem I have is the 2 levers that pin the booster rod and the pedel rod come all the way back and hit my freshly painted firewall. Its like the rod on the brake pedel isn't long enough. It doesn't even allow the brake pedel to rise all the way up to it's stop, the levers hit the firewall before the pedel returns all the way. I tried to adjust the pedel rod out, but ran out of threads. We had the same problem on my dad's 72 and he had a new and longer pedel rod made. Since this is the 2nd truck we did with this problem i figure we're doing somethin wrong.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 01-19-2004, 04:59 PM   #2
71Chev
71Chev's Avatar
You have to get the power brake pedal rod also. The rod for power brakes is longer than the rod for non power brakes.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 01-19-2004, 05:14 PM   #3
Low69CST
This should be a power brake rod, aren't non-power rods just have a rounded tip on the end, like on the inside of my brake booster and power rods have a eye in the end for the pin to go through on the pivot rods, right??
Old 01-19-2004, 05:29 PM   #4
71Chev
71Chev's Avatar
Yes the power brake rod have an eye on each end. What year did the booster, rod, and firewall bracket come off of?
Old 01-19-2004, 05:33 PM   #5
Low69CST
I'm not sure what year they came off of. We just have a collection of parts and I picked out the best lookin.
Old 01-20-2004, 08:06 PM   #6
Low69CST
anybody else?
Old 01-20-2004, 08:15 PM   #7
Primed67
Primed67's Avatar
I would say that you have the wrong pedal rod in it. You said that you were not sure what year it came out of. When I converted mine I took the MC, the booster and the rod out of a 72. Mine worked like a charm.
1969 Chevrolet SWB Stepside
1959 Chevrolet apache * Sold
1967 Prostreet Chevy SWB Fleetside *Sold
2014 1/2 ton Crew Cab Chevrolet 4x4
Primed67 is offline   Reply With Quote
Old 01-20-2004, 08:37 PM   #8
Low69CST
I dunno, if someone has a rod they know came out of a 72, if they could measure it, i'd appreciate it
Old 01-20-2004, 08:44 PM   #9
71Chev
71Chev's Avatar
A 67-72 power brake set up bolts right in if you get the rod, bracket, and booster from a 67-72. I'd say find a known 67-72 set up and get it.
Old 03-22-2004, 02:02 AM   #10
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Don't worry. Mine doesn't hit the rubber bumpstop either. I did the conversion on my '70 2 weeks ago. I got the bracket off of a '70 that had the power brake option. I just used it as a good excuse to have my brake pedal closer to being even with my gas pedal, so that it is easier to get my foot on the brake pedal. I hated how high it was before power brakes. My pedal doesn't move much at all, so I'm not worried about hitting the floor.
I don't think your doing anything wrong. The only thing that I can think of, is to replace the pedal assembly from a pwr brake truck. I took the pedal assembly from the donor truck, but didn't care enough to swap, or even measure to see if there was a difference. I just don't worry about it.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 03-22-2004, 08:40 AM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Here's a 72 setup from the back...
Old 03-22-2004, 10:40 AM   #12
Low69CST
Sweet,
What stops your brake pedal from coming all the way up? On my truck, the 2 fingers in the picture above were coming back and hitting the firewall. That was being the true stop for brakes. I was thinking the booster should stop it or it should rest on the pedal stop? What does the actual stopping on your setup? PPG paint is expensive, i don't like having big pieces of steel smacking it
