Old 01-25-2026, 10:57 PM   #1
Jesse72
Active Member
Jesse72's Avatar
Stock steering wheel on Ididit column
I couldn’t find much info on this but I was able to get my stock wheel to fit my ididit column. I did have to do a few modifications to make it work. The taper on the stock wheel was slightly off from the ididit column so I used a Dremel with the sandpaper wheel and slowly enlarged the “Smooth” portion of the wheel below the splines. I had to drill a new hole to clock the canceling mechanism and get a different horn pin.
Pic 1 shows the large gap between the wheel when I originally tried to put it on.
Pic 2 shows the closed gap aver using the Dremel. I took the wheel on and off 4-5x and slowly got it to seat down so I didn’t take too much material off.
Pic 3 is the new hole drilled circled in red.
Pic 4 is the factory horn pieces
Pic 5 is the ididit hot button you will need. This needs to be trimmed to sit about 1/16-1/8in above the center of the wheel so it doesn’t contact the concave horn ring. When you depress the horn button it will then touch.
Hopefully this helps someone.
Jesse
72 4x4 Sold
59 GMC air ride ls swap
61 GMC 1001 Carryall
Jesse72 is offline   Reply With Quote
