I replaced my rubber fuel lines
Today I replace the rubber fuel lines. The old ones were getting pretty crusty and were about a hot summer or few good bumps from giving out. I loosened the rear line under the cab from the tank to the steel line and it started to leak as soon as I loosened the clamp. I think it was worn where the clamp and home met the bulge on the line. I put the rounded edge clamps on everything and I should be good to go for a while.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
