Old 01-19-2004, 04:47 PM   #1
Keep on Trukin
Turn signal question?
Has anyone delt with this problem, everytime I make a left turn my blinker flashes until I hit the brakes, then the blinking gets cancelled out, does anyone know where i can start, to find the problem. I checked all the wiring it looks good and the bulbs are ok? HELP!
Keep on Trukin is offline   Reply With Quote
Old 01-19-2004, 08:37 PM   #2
rage'nrat638
rage'nrat638's Avatar
man have not heard that one before
ok ....i would start at the blinker switch under the steering wheel...
have no clue why they go out when you hit the brake pedal....
unless your head's hitting the steering wheel and making the blinker turn off.....J/K
THATS THE SWITCH......are they canceling them self's after the turn is made???
after 30 plus years a lot of crud builds up in there....
keep us posted
THE RAGE
rage'nrat638 is offline   Reply With Quote
Old 01-19-2004, 08:47 PM   #3
DUBURBAN
DUBURBAN's Avatar
99% of the time with DC current, its a bad ground. Look at all your ground connections and clean them too!
DUBURBAN is offline   Reply With Quote
Old 01-19-2004, 08:50 PM   #4
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I had a problem similar to this. Except it was my brake light on the driver side. It would light up while on the brakes but if I turned the headlights on, I wouldn't have a brake light. It ended up just being a bad ground. I tightened up the 5/16's bolts behind the taillight and I haven't had a problem since.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 01-19-2004, 08:51 PM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
I agree....bad ground. They will do some werid, werid things....
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 01-19-2004, 09:42 PM   #6
Gordo
I would suspect the signal switch if all the grounds and bulbs are good.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 01-19-2004, 11:28 PM   #7
da-burb
"Ochre Ogre"
da-burb's Avatar
Someplace in your truck you have the blinker fluid line crossing under the brake line. You step on the brakes and it stops the blinker fluid from flowing to the turn signals. Sorry man, it's expensive to fix.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 01-20-2004, 12:09 PM   #8
6T9GMC
6T9GMC's Avatar
T/S SWITCH
HELLO,
I have a 1969 and I had a simalar problem. When I didn't have signals on, the brake lights worked fine. When I had a turn signal on the opposite brake light would go out, so if i was stopping and turning I wouldn't have any brake lights on opposite side, but signal would work fine. I changed the turn signal switch and it fixed the problem.
It wasn't even that bad of a job!
I hope this helps!
6T9GMC is offline   Reply With Quote
Old 01-20-2004, 03:42 PM   #9
Keep on Trukin
Many years of experience helps alot, thanks you guys!
I will check my grounds and or my turn signal switch.
Old 01-20-2004, 05:05 PM   #10
KEH
Better late than never
KEH's Avatar
I have a similar problem. My left brake light will not work, unless I use the left turn signal and then cancel it. Then it works for a period of time. I haven't determined when the brake light stops working again, but it doesn't last long. The grounds are good, as well as the wiring. I'm thinking it must also be the turn signal switch.
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 01-20-2004, 05:07 PM   #11
1972C10
1972C10's Avatar
Ive seen bulbs blow and one of the fillaments lands on the others and causes similar problems when stopping.
1972C10 is offline   Reply With Quote
Old 01-20-2004, 05:41 PM   #12
Jace's68
Jace's68's Avatar
Having the wrong bulb can also cause crazy things to happen. I had a trcuk that when you stepped on the brakes, the front pariking lights lit up. Turned out that someone had forced the wrong type of bulb into one of the rear lights. More than likely though you have a loose ground somewhere.
Jace's68 is offline   Reply With Quote
