Old 01-31-2026, 08:06 AM   #1
Question about the width of front and rear differentials…
So my question; is the front differential wider than the rear on a 69-72 Blazer ?
Old 01-31-2026, 09:17 AM   #2
68panelman
68panelman's Avatar
Re: Question about the width of front and rear differentials…
Yes, Blazers use the same Dana 44 as the other K-series, so wider front for tracking purposes they say.
68panelman is offline   Reply With Quote
Old 01-31-2026, 09:22 AM   #3
Thanks !
Old 01-31-2026, 11:39 AM   #4
hemi43
hemi43's Avatar
The track on the rear is around 4" narrower. That's why they look goofy going down the road especially when viewed from behind. I machined 1 7/8" thick wheel adapters to get rid of this problem.
hemi43 is offline   Reply With Quote
Old 01-31-2026, 01:09 PM   #5
Is the wider front only on the 4X4 Blazer ?
Old 01-31-2026, 01:55 PM   #6
hemi43
hemi43's Avatar
I'm not sure if the 2wd Blazers are wider up front, but I highly doubt it. The difference in track was designed for traction so that the rear wheels could bite into fresh mud/snow.
Old 01-31-2026, 03:22 PM   #7
Thanks hemi,
I wonder it the wider front end applies to the K series trucks from 67-72 also ?
Old 01-31-2026, 04:57 PM   #8
hemi43
hemi43's Avatar
Thanks hemi,
I would assume they would be the same because as far as I know they used the same front and rear axle widths.
Old 02-03-2026, 06:29 AM   #9
Richard
They are the same for trucks and Blazers. I got this response with a search.
The wider front axle on older 4WD trucks is primarily a mechanical design necessity, not a performance enhancement for traction or handling.
Clearance for steering: The front axle must be wider to allow the front wheels to turn without interference from the frame, springs, or steering components. This is especially critical with solid front axles and large tires.
Shared rear axle design: Manufacturers often used the same rear axle housing for both 2WD and 4WD models. The front had to be wider to accommodate steering knuckles and differential clearance, while the rear remained narrower for packaging and cost efficiency.
Tire rotation and spares: A consistent front-to-rear track width (or near it) allows for full tire rotation and use of a single spare, simplifying maintenance.
While some claim benefits like improved stability, reduced rut-following, or Ackermann optimization, these are secondary or misconceptions. The core reason is mechanical packaging — the front end simply needs more width to function.
What I have always believed.
Richard
