Old 01-31-2026, 11:22 AM   #1
twoskies
twoskies's Avatar
Another VIN Question
Morning
Indiana
i had the 1966 c10 plated and insured before tearing it down, never really drove it, motor never ran quite right, started as a motor teardown, snowballed into a cab off to fix some rust issues, ended up all the way apart
the cab has the correct VIn tag
The Frame does not, i know after reading some other posts it should be the last 6 digits, but its different, frame swap at some point ?
i do know the cab had alot of bondo in it, which ive removed and fixed, skim coat of filler should be it at this point
What do you do at this point
1) Leave it and put it back together/drive it
2) Check with DMV
Any help appreciated
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
