Old 01-19-2004, 05:54 PM   #1
70short/step
70short/step's Avatar
Rear Sway bar
I have heard that a 82 to present Camaro rear sway bar will work with 67-72 trucks. I have only seen it used with coil rears. Does anyone know if it will work with leafs??
Thanks 70short/step
70short/step is offline   Reply With Quote
Old 01-19-2004, 06:37 PM   #2
Low69CST
I'd think the bar would hit the leafs. You might be able to raise it to miss, or if you used a flip kit to lower the truck, i think that would cure the problem.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
