WHYBYNU when old will do?
Lowering rear with blocks - ??s
I've got a 72 Chevy with a coil rear end and I'd like to even out the stance a bit. I've been reading some of the posts on the board, and have a few questions. A lot of people are using thick walled square stock and boxing the ends, then getting longer U-bolts. Is this all that needs to be done? Are there any other concerns, like panhard bar, shocks, bumpstops, etc., that I should worry about? I'd lower it a bit with springs, but I eventually (hopefully in a few years) will go to airbags, so I don't want to waste the money on springs. Thanks for the help, here's my truck right now as it stands. I'd like to get it almost even or just a slight rake, only maybe a 1-2" drop in the rear.
-72 Chevy C10 Stepside -2002 Chevy Silverado 2500HD 4x4 -1984 Jeep CJ7 -1995 Polaris XCR600 Custom -2003 Honda 300ex |
Watch out for your cornhole !
![]() Join Date: Jun 2003
2 inch blocks are a straight in deal. It won't offset the rear enough to warrant adjustable panhard bar or pinion angle problems. Build the blocks and buy the u bolts and that's it.
Almost too good to be true isn't it?
Lowering your truck 1-2in you don't need to worry about panhard bar, shocks or bump stop. When you get to 4in or more then its time to get an adjustable panhard and maybe some shorter shocks bump stop will still be fine.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
![]() Join Date: May 2002
Anyone tried lowering more than 2" this way? Say 4"?---sure would make for long u bolts!
Stepsides look like real trucks! Smitty ![]() |
You shouldn't lower one that low with blocks. It puts the lower shock mounts below the scrub line.
Here's a picture of one I did awhile back. Now, imagine if the shock was 2 inches closer to the ground. It would place the shock lower than the bottom of the wheel. That way, if you ever had a flat, it would allow the shock to dig into the pavement. Very unsafe.
What you say is very true, but then I think the shock mounts should be relocated regardless of the amount lowered--they don't work right even with 2".
Try running some stock 68-70 chevelle springs. They'll fit perfect and they're made for a car not a load. You should drop about 2 1/2" or 3".
firefighter,did you make or buy those spacers?
The blocks? I made them
#10 | |
If patience is truely a virtue, Then I am so screwed 1970 Chevy SWB 331 sbc and all the goodies. Under resurection 2001 Vette |
