Old 01-19-2004, 06:20 PM   #1
mike63078
3 speed to 5 speed
Ok guys i just picked up a 78 c10 short bed 250 with a 3 speed manual. I am looking to put a 5 speed into it because the 3 speed is sticking. what trans will bolt up and work with little modification? what clutch do i use? thanks
mike
mike63078 is offline   Reply With Quote
Old 01-19-2004, 06:39 PM   #2
r0lf-
Hotwheels?
r0lf-'s Avatar
The 88-98 trucks that were manual were 5 speed I believe. Thats probobly your best bet without spending a ton on an aftermarket tranny. Sorry, I dont have the model name of the tranny. Id guess M5 though.
They probobly use a hydraulic clutch though (yuck )
Ill see if I can dig up any more info.
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 01-19-2004, 06:46 PM   #3
mike63078
I am looking for something bolt in that will work the same as the 3 speed. i could do a 4 speed but would liek to have an OD
Old 01-19-2004, 11:18 PM   #4
r0lf-
Hotwheels?
r0lf-'s Avatar
Well... there were no manual trannys that had OD offered I our trucks. Or atleast im pretty dang sure. You can probobly find a muncie 4 speed, they were offered. But they just have better gearing than the 3 speed. They both have a 1:1 last gear.
Then there was the 4x4 and work truck 3 speed with low
I had an extra one, but it got ruined due to water, so it got sent to the junkyard.
Old 01-19-2004, 11:20 PM   #5
mike63078
i think i will get a muncie for the gearing i got a 355 rear so its not that bad
Old 01-20-2004, 09:09 PM   #6
truckman32
AND HOLDING ON TO THE C10
truckman32's Avatar
have you consider a s10 5 speed tranny i have heard of this swap in the older 55-72 trucks so it should work fine with the 6 banger in your truck
66 swb/ss chevy c10 SOLD
62 swb/fs chevy c10 :p SOLD
84 swb/fs chevy c10
91 sdime 383/th350
truckman32 is offline   Reply With Quote
Old 01-20-2004, 09:46 PM   #7
mike63078
that would work do u know any details?
