Aluminum Radiator Leaking
Noticed the aftermarket aluminum radiator in my truck is starting to let go. It appears it's starting to seep where the tubes meet the end tanks. I've always ran 50/50 mix AC Delco coolant water, 180 degree thermostat. I'm in Florida so no issues with severe cold. The previous owner installed it so I have no idea of manufacturer or how old it is. My question is why is this happening? Cheap-o radiator or something else?
58 Fleetside 71 Cheyenne |
Re: Aluminum Radiator Leaking
Can't tell you why it's happening. I'll get push back from what I have done in the past. Alumaseal powder and not the liquid. It stops seeping. Heck a long time ago when we were teenagers my buddy put an old firetruck radiator in his 37 chevy with a 409. Pinhole leaks everywhere. Don't know where he got the suggestion (way before internet), but he used black pepper. It worked! Not saying to try it. Best bet is a new radiator. Tight on cash try the alumaseal powder.
Moderator
![]() Join Date: May 2007
Bars leaks has always worked for me. I’ve heard of the black pepper working too back in the day
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Just a note on alum radiators. On my LS swaps I always use the rubber stock? upper and lower radiator mounting system.
Brackets welded to the side tanks bolted to the the rad support can flex a bit and over time cause leaks. Pic of my LS swapped 68 with an aftermarket generic LS Afco rad using the stock rad mounts upper and lower. |
#5 | |
I ordered up some Bars for now.
That's too bad they stopped making it. Does anyone remember the original Bars Leak that looked like chucks of licorice is some fluid?
![]() Join Date: Apr 2016
My dad was born in 1924. He told me stories of way back when they would use horse manure, black pepper or raw egg. The bits would plug the holes and the egg would gum it up. It only kinda worked because cooling systems were very low pressure. They did what they had to during the depression.
1972 GMC K2500 Super Custom Matt |
#9 | |
Moderator
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
We used to call those chunks in the Bars Leaks "rabbit turds". Anyone remember "dog turds" for stopping radiator leaks? They were some sort of grayish pellets about 3/4" thick and 1" in diameter. Black pepper actually will work, short term. I bought a '40 Chevy from a guy who had used Bars Leaks. The heater didn't work all that well after a glob mostly closed off one of the adapter pipes at the water pump. About froze my keister off, driving it in Idaho.
The Niner
![]() Join Date: Nov 2010
I've used these... just relabeled Bar's Leak.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
![]() Join Date: Jul 2021
I remember, I had to use some back in the early 80's because that's all I could afford at the time. Later I fixed the radiator right. The Bars Leak helped.
Darrell ![]() 1972 Cheyenne Super C20 (Heavenly Too) (My Street Truck) 2000 S10 Xtreme (Black Magic) (My Drag Truck) |
#13 |
That is a common place for them to leak. Hard to say if the radiator is cheap or not. It could be due to vibration or worn mounts. If the radiator gets twisted a bit from the worn mounts, it will break the tubes away from the header panel.
#14 |
![]() Join Date: Feb 2022
Stop leaks good to get you by till you have time for proper repair on daily driver. Not good for second or play vehicle. If the radiator or other cooling system passages are tightening up with corrosion, what do you think all those extra partical in the coolant are going to do.
#15 | |
#16 |
Is this something that can be repaired or am I looking at a new radiator? Either way I can either purchase or fabricate better mounts.
#17 |
#18 |
A pepper shaker from a fast-food restaurant got me home from the drag strip in my 55 Belair in the wee hours of the am.
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
#19 |
![]() Join Date: Jun 2022
It being Florida, I'd wonder if the environment attacked and pitted the aluminum from the outside, since the inside was fully protected from corrosion
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
#20 |
Yup, look like the old dog turds. I think we had a different brand, though? It has been over 50 years...
#21 |
![]() Join Date: Jul 2001
For what it's worth I'll attest to the black pepper "fix" as a temporary to get you home again. I was in the US Army 3rd Armd. Div. serving in Germany in the late 60's. Yup, I'm old, LOL. On maneuvers for Cold War training and one of our jeeps sprung a leak in the radiator. Our old time Motor Pool Sgt. who had served in WW2 told the driver to stop by the Mess tent and grab some black pepper from the cook. Let the radiator cool enough to open the cap and throw in a couple teaspoons of pepper. Topped off the radiator coolant and it never leaked any more during our training field time. Got back to the post and then the radiator was changed out. It does work for a small leak and in a tight situation,
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#22 |
So that's the reason I don't leak as much as I used to. I think I ate some of those chucks of licorice. There was no warning on the can.
#23 | |
#24 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
#25 |
Aluminum radiators will have problems with electrolysis if not isolated. After mounting and before hoses are attached, check for grounding. If there IS continuity to ground look for metal to metal contact and correct. Not only will you avoid electrolysisdamage, you will eliminate a possible rub point were vibration could create a hole.
| Bookmarks |
