Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 02-12-2026, 10:01 PM   #1
Gromit
Door Spot Welds off in 48 Secs - What's Underneath?
Makes me wonder what is underneath my doors - she makes it look so easy to take them apart, check this one out: (text in quotes below is her narrative).
Fabricating Custom Doors - 64 Toyota Stout Build
https://www.youtube.com/watch?v=Z3YMn3X25F0
10,991 views Premiered 10 hours ago
"Because the cab has been extended 60mm, roof chopped about 50mm, body dropped 100mm and sectioned 50mm, the original doors no longer fit.
At this point it was easier to begin with a blank canvas and make something more aesthetically pleasing than using the original farm truck styled inners. The exception of these being completely hand made was using the original hinge mounting face at the front, it didn't make sense to change that part for the sake of it when it worked once a 100mm section was removed.
In this video I show the complete process of building these doors up until the stage you can see in the cover photo. I begin by stripping down the original doors seam by seam to work out what bits I can use and reference from.
I talk about treating the door like a jigsaw puzzle, starting with locking in the border (like the edge pieces) before filling in the blank space in the middle. This is a perfect example where form and function need to work hand in hand. There are a lot of moving components within the small door space, I had to modify a lot of the mechanisms in order to work with my design but the design was also largely influenced by the limitations of these components."
Gromit is offline   Reply With Quote
