Old 02-15-2026, 02:10 AM   #1
Luke87gt
Luke87gt's Avatar
Can we talk brakes?
Hi guys,
‘69 c10 here with drum brakes at all four corners (manual).
I have a set of 2.5” drop spindles sitting in the garage and I’d like to do a front disk brake swap. I’m hoping you guys can steer me in the right direction taking into account performance and value. Few things:
a.) I have 15x8 rally wheels which I’d like to keep. Any brakes I go with should fit under those wheels.
b.) I’m undecided whether to stay manual or go power. I’m ok to stay manual as long as the pedal isn’t too crazy. I’ve heard some guys say that manual brakes can result in a decent user experience if they are set up right.
c.) If you were in my shoes, what route would you go? Looking for recommendations on booster/MC, rotors, calipers/pads… or a simple kit.
Also, for my reference, do 71-72 disk brakes fit the ‘69 with aftermarket drop spindles intended for the ‘69?
Thank you
Thank you!
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 02-15-2026, 12:14 PM   #2
raggedjim
raggedjim's Avatar
Re: Can we talk brakes?
Read these links
https://67-72chevytrucks.com/vboard/...d.php?t=444815
As far as manual verses power I plan to run manual and some people do. Most people prefer power.
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 02-15-2026, 12:38 PM   #3
67swb72klb
67swb72klb's Avatar
I swapped my 67 to disc and stayed with the manual set up and they work good..
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 02-15-2026, 01:26 PM   #4
Luke87gt
Luke87gt's Avatar
Thank you
What MC / caliper setup did you go with?
1969 C10 Shortbed
Old 02-15-2026, 02:21 PM   #5
Luke87gt
Luke87gt's Avatar
Originally Posted by raggedjim View Post
Read these links
Good luck, Rg
Thank you for the link, helpful info! I will be staying 6-lug.
What about calipers, will the 71-72 calipers work with my drop spindles? I don’t recall if the calipers just bolt up to the spindle or if an additional bracket is needed between the spindle and caliper.
Debating between
a.) Wilwood MC and calipers
Vs
b.) 71-72 stock calipers and MC
Or if there is any other popular options that people here recommend, glad to consider that as well. Would like the truck to stop well without blowing the bank.
Thank you.
PS: if I stay manual brakes (disk front, drum rear), is there any particular MC size I’m looking at to have a pedal effort that won’t make the truck a chore to stop?
1969 C10 Shortbed
Old 02-15-2026, 03:32 PM   #6
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
If you stay with the size caliper that came on the '71-'72 and if those rotors will fit with the drop spindles, then the manual master cylinder for those years will work. I've driven trucks and cars with manual disc brakes when I worked for Chevrolet dealers. Pedal effort is higher, but not by that much. It's just a surprise at first when you jump in to drive and it's not assisted.
~Steven
Simi Valley, CA
Old 02-15-2026, 04:31 PM   #7
Luke87gt
Luke87gt's Avatar
Thanks Steven, is the 71-72 MC a direct bolt on?
Just remove my MC and bolt on the 71-72?
Then I always think, is there any later year “upgrade” I should consider that will offer improved performance?
I ask because other than the spindles, I’m starting from scratch. So now is the time to piece together a plan. Thank you
1969 C10 Shortbed
Old 02-15-2026, 04:42 PM   #8
Steeveedee
Steeveedee's Avatar
I don't know that answer. Maybe find someone with a '71-'72 with manual disc brakes and compare?
Someone on here probably knows.
~Steven
Simi Valley, CA
Old 02-15-2026, 04:55 PM   #9
Rust_never_sleeps
Rust_never_sleeps's Avatar
If you do wade into the power vs manual threads, kits have changed over the aeons and you probably won't need to worry about pedal leverage and rod angle because of the cantilever aka bell crank in the MC mount. I chased my tail for a while
https://mpbrakes.com/bellcrank-classic-cars/
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 02-15-2026, 05:08 PM   #10
Rust_never_sleeps
These guys put nice clear tech info out there:
https://mbmbrakes.com/tech/
Old 02-15-2026, 05:14 PM   #11
70STOVEBOLT
70STOVEBOLT's Avatar
I used McGaughy’s spindles and all other parts are stock 71-72 parts so I can go to the local parts store and not have to order replacement parts online. One thing to note, your drop spindles may require the use of 71-72 tie rod ends. Mine did not. Also I went the power route.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-15-2026, 05:48 PM   #12
67swb72klb
67swb72klb's Avatar
Originally Posted by Luke87gt View Post
Thank you
All stock 72 stuff
Old 02-15-2026, 06:31 PM   #13
dmjlambert
dmjlambert's Avatar
I recommend manual brakes. I have 71 brakes on my 69 and it works just fine. This is the thread I recommend for the master cylinder, https://67-72chevytrucks.com/vboard/...39#post9169739. Counter people at 99.999% of car parts stores and online suppliers are not going to find the "correct" master cylinder, that is my opinion. Use NAPA part M36280 new master cylinder for manual-brake 1/2 ton C-10 disc/drum setup.
For proportioning valve I used a stock 72 combination valve and sent it to White Post restorations. I bought it by posting a want-to-buy thread in the parts section. There is a thread somewhere on this forum showing pictures and describing how the spring in the back end of the valve is different for 1/2 ton, 3/4 ton, and 1 ton, it affects how much braking the rear drum brakes will get with the different gross weight trucks. I can't find the thread again. I don't know if my combination valve is from a 1/2 ton, but I suspect it is because the braking feels like it is evenly distributed. If you don't know the pedigree of a combination valve you buy used, there is some risk of ending up with one from a different gross weight truck.
dmjlambert is offline   Reply With Quote
Old 02-16-2026, 09:17 AM   #14
Jason Banks
Jason Banks's Avatar
The 71 72 style brakes work great either power or manual. I have converted a few. I had not done a non-power set up until the last one and am very pleased how well they work.
I had and LS swap with a cam, with a power brake booster. Because of the cam it didn't make much vacuum at low RPM and I always felt like it required tons of brake pressure. For my next one I went manual(no booster) and it's way better. I did recently upgrade to the EBC yellowstuff pads which are a higher friction pad, but haven't driven on them enough to say it was a great upgrade...
Jason Banks is offline   Reply With Quote
Old 02-16-2026, 10:38 PM   #15
67swb72klb
67swb72klb's Avatar
I just put a adjustable proportion valve in the rear at the T.
Old 02-28-2026, 11:31 PM   #16
vardenafil
Did you need any adapters for the adjusting valve? Im going to add one to my truck as the rear end locks up way to easy compared to the front. what proportion valve did you go with?
vardenafil is offline   Reply With Quote
