Old 02-15-2026, 06:54 PM   #1
Luke87gt
Luke87gt's Avatar
1969 Saginaw 3-speed, no drain plug?
Hi guys, headed into the garage this afternoon to change the transmission oil (1969 c10, 3OTT transmission) - 80w-90 gear oil
I get under the car and to my surprise, I don’t see a drain plug? There is a fill plug. I guess the early Saginaw 3sp transmission may not have had a drain plug?
What then is the recommended method to change the oil?
Also, I notice that one of bolts (transmission to bellhousing) has a snapped off head. The fun things you discover when you buy a 56yr old vehicle.
Thank you
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 02-15-2026, 10:02 PM   #2
jumpsoffrock
Re: 1969 Saginaw 3-speed, no drain plug?
Are you sure the "snapped off bolt" isn't just coming from the other direction? Not sure about your drain plug issue.
jumpsoffrock is offline   Reply With Quote
Old 02-15-2026, 10:13 PM   #3
Mine had a drain plug in about the location of the. The two bolt looking ones close together, the upper was my drain plug. I wonder is someone put another type of bolt instead of the pipe plug in there.
Old 02-15-2026, 10:49 PM   #4
Luke87gt
Luke87gt's Avatar
Interesting, I’m not aware that there is a bolt that’s accessed from the inside of the bellhousing? I guess if the head snapped, it probably would have done so flush (here a short length is protruding)
Can anyone confirm what this is in the picture?
1969 C10 Shortbed
Old 02-15-2026, 11:15 PM   #5
Luke87gt
Luke87gt's Avatar
Grok says the following
1969 C10 Shortbed
Old 02-15-2026, 11:19 PM   #6
Sicklajoie
The Niner
Sicklajoie's Avatar
The bottom bolt that connects the tail shaft to the main housing can be used as a drain plug.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 02-15-2026, 11:29 PM   #7
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
I remember putting clutches in pigs like this with the bolts threaded into the trans. It's a real time-eater when you're working against the clock.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 02-15-2026, 11:35 PM   #8
Luke87gt
Luke87gt's Avatar
I just got under the truck again.
Confirmed that the two lower transmission bolts are coming from the inside (can’t see the bolt heads). The two upper bolts are coming from the outside (can see the bolt heads).
Seems to match what Grok is saying.
Why did GM do this? I’ve never seen this before in any car I’ve ever worked on before this one. Really threw me for a loop when I first saw the end of the bolt staring at me in the face lol
1969 C10 Shortbed
Old 02-16-2026, 07:22 AM   #9
HalfBrit
When I still had the 3 speed, in my '70, I drilled and tapped that blank boss for a '98 GM style magnetic tip O-ring equipped oil drain plug.
HalfBrit is offline   Reply With Quote
Old 02-16-2026, 09:03 AM   #10
68panelman
68panelman's Avatar
Every manual transmission bell housing bolt this way, all my 4 spds and three on the column trucks, I'm sure the General had some reason for this bolt pattern
68panelman is offline   Reply With Quote
Old 02-16-2026, 11:16 AM   #11
Steeveedee
Steeveedee's Avatar
^ On most trucks? I've seen them both ways, and every standard trans I had in a car, the bolt heads were outside the bell housing.
~Steven
Simi Valley, CA
Old 02-16-2026, 11:35 AM   #12
Both my 70 step side, 6 cylinder truck, and my 64 C10 had the bolt heads on the outside. The 70 V8 I have now had the bolts backwards (to me anyways) with heads inside the bell housing, rear engine mount thing. Maybe twhether it was originally a V8 versus 6 banger was a difference. NOt sure, just know that the 69 3 speed I put in my 64 (which had a V8 by the time it got to me) was with heads out. AS mentioned, all cars I have had had them outward.
Old 02-16-2026, 01:56 PM   #13
Luke87gt
Luke87gt's Avatar
Interesting…
It makes me wonder what is the sequence to removing the trans when two of these bolts are coming in from the inside.
Say I’m doing a clutch job… I’m sure it’ll all make sense once I finally get in there one day.
1969 C10 Shortbed
Old 02-16-2026, 02:41 PM   #14
68panelman
68panelman's Avatar
Yes, correct. I just looked at my sm318 overdrive transmission from a tri five Chevy car and all mounting ears are threaded
Old 02-16-2026, 03:30 PM   #15
Steeveedee
Steeveedee's Avatar
All four heads are inside the bell housing? Oh, what joy.
~Steven
Simi Valley, CA
Old 02-16-2026, 03:52 PM   #16
68panelman
68panelman's Avatar
Yeah, I imagine a PITA. I acquired this transmission a little over a year ago, without bell housing, who knows what has been done to it in the past 70 years. Still figuring things out Plan on installing in my 67 with 3ott, bottom picture
