New Member
![]() Join Date: Oct 2023
C30 dually Cummins swap
Has anyone used a 3 core aluminum radiator instead of using a dodge radiator?
I’d like to keep to the same height and width of the stock size. Would that keep the Cummins cool enough? I’m keeping motor stock for now. Maybe a bigger turbo and injectors someday. |
New Member
Re: C30 dually Cummins swap
Nobody?
I'm running the stock 72 radiator with no problem with heat. Modified turbo and fuel pin and governor spring. Haven't towed with it though but never gets above normal temp.
New Member
Thanks. Appreciate the info!
| Bookmarks |
