Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 02-26-2026, 07:37 PM   #1
IT Cowboy
IT Cowboy's Avatar
Could I put screws in valve covers or dumbest idea ever
I have a set of metal strip spark plug wire looms I am wanting to add to tidy up under my hood. The wire looms are supposed to bolt onto the valve cover bolts at the bottom but they are tight there especially with my AC compressor on the one side. They would fit nicely on top of the valve cover right in the center. Could I use short self tapping screws to put them in the cover or am I inviting problems and leaks. My other idea was to try 3m high heat mounting tape.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
