Old 02-27-2026, 03:16 PM   #1
StMartin55
Binding whene backing
My 72 C-10 feels like the wheels are binding when backing up. Everything is new, differential has been rebuilt, new drive shaft, tremec 5 speed trans. This is when backing with the wheels turned, doesn't matter which direction.
Any Advise would be helpful.
StMartin55 is offline   Reply With Quote
Old 02-27-2026, 04:39 PM   #2
truckster
truckster's Avatar
Re: Binding whene backing
Have you tried adjusting the shoes on the drum brakes in the back?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 02-27-2026, 05:20 PM   #3
HO455
HO455's Avatar
New posi in the rear axle?
RIP Bob Parks.
Old 02-27-2026, 05:21 PM   #4
HO455
HO455's Avatar
Welcome aboard!
RIP Bob Parks.
Old 02-27-2026, 05:49 PM   #5
PbFut
Did you add friction modifier when you filled the rear end?
PbFut is offline   Reply With Quote
Old 03-03-2026, 04:37 PM   #6
truckdude239
truckdude239's Avatar
moved to drivetrain forum please try to post in the proper forums
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-04-2026, 02:12 AM   #7
leegreen
This is 2wd right? So no front drive axle issues to worry about.
Does it release as soon as you pull forward or straighten out in reverse?
Brakes binding in reverse: I'd check rear drum brakes are assembled properly, particularly the return spring, ebrake rod and hold down spring on the rear shoe and make sure the shoes can slide back and forth across the backing plate without getting hung up in a groove worn into the shoe support pads
Brakes binding only when you turn implies wheel bearings, tire rub, end play in axle shafts or a differential locking issue
binding only in reverse when turning....maybe two problems
leegreen is offline   Reply With Quote
wheel binding
