Old 03-03-2026, 10:49 PM   #1
IT Cowboy
IT Cowboy's Avatar
WTB - carb idle stop solenoid
I am looking for a carb idle stop solenoid that goes on the drivers side of a Rochester / Carter 4bbl carb and turns on with 12v and then retracts when no voltage is present.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
