My truck starts up much better using this one simple trick
Ok, not a trick and not clickbait either, but I adjusted my fast idle this evening on my divorced choke Rochester carb. It now starts up at 1100 rpm and then settles down to @750 with the first blip of the throttle.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
