Old 03-09-2026, 01:59 PM   #1
JAZ72C10
New Member
JAZ72C10's Avatar
Windshield Washer Help
Installed a new original reproduction washer pump from Classic Parts. I tested it before I put the dash back together and the washer squirts fluid on the windshield continuously. It only stops when I shut the wipers off completely. Is the on off switch itself bad? OR is it the new pump? I disconnected the power to the pump itself and it continued to pump washer fluid. The pump also seems to be leaking where the piston enters the pump chamber. Did I just get a bad unit?
1972 c10
JAZ72C10 is offline   Reply With Quote
