Old 03-10-2026, 09:52 AM   #1
Loose Screw
Loose Screw's Avatar
Mini Starter...Are You Happy With Yours?
Tryin to uninstall/install an Original 40/50 lb Delco starter around exhaust pipes on your back is not an easy task...
Anybody had any luck with a "Mini" Starter?
Yeah, and I got the off set bolt to block starter with the purple and yellow wire (points) solenoid...
Loose Screw is offline   Reply With Quote
Old 03-10-2026, 10:06 AM   #2
Sheepdip
Sheepdip's Avatar
Re: Mini Starter...Are You Happy With Yours?
Have one on all of my "not modern" vehicles including my 1946 CJ2A 4 cylinder Jeep...not that it's hard starting it's just that these things are bullet proof reliable.
Everybody used to make fun of the Crysler gear reduction starter whine back in the day, but those where proven to be the most reliable.
Sheepdip is offline   Reply With Quote
Old 03-10-2026, 10:14 AM   #3
I put on a Proform Starter Motor (#66256) on my 70 when the original went out. It was a super pain getting out original with full length headers. I used this one as it was one I had from my prior truck's build. Starter has been on this truck almost 4 years, plus year or 2 on last truck. Does great Lot easier to get in especially since I went to shorter headers.
Old 03-10-2026, 11:38 AM   #4
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
My mini starter is a Hitachi from a local speed shop. It's been in there for 12 or so years. Works like a champ!
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 03-10-2026, 12:15 PM   #5
biketopia
A factory gear reduction starter from like a 4.3L S-10 works great and is available at your local parts store. I have one on my Blueprint 427 SBC and it has worked flawlessly.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 03-10-2026, 01:03 PM   #6
Shifty One
Shifty One's Avatar
I've used them in every Chevrolet I've needed to put a starter in with no issues at all. The only thing that I'd recommend, is don't "long-crank" them, they heat up fairly quickly.
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 03-10-2026, 01:13 PM   #7
Loose Screw
Thanks My Brothers!
Proform *66268* Spec Sheet Says: 8.3 lbs.
Heres some pix...
Think I'll get it from Summit, I like their Customer Service compared to the *others*, ~$145 OTD...
Old 03-10-2026, 01:46 PM   #8
pjmoreland
pjmoreland's Avatar
I have a Powermaster 9612 that I installed a few years ago. It has worked fine, and it has no problem clearing my headers. One minor issue I ran into with it was that it sat too far away from the flexplate, so I had to machine about .020" off of it where it sits against the engine block to get the teeth to mesh properly.
https://www.summitracing.com/parts/PWM-9612
pjmoreland is offline   Reply With Quote
Old 03-10-2026, 02:46 PM   #9
Loose Screw
Yeah, a Powermaster *seems* to be a better quality starter than a Proform, nowadays that ain't saying much really. A 9012 Powermaster would need a little more fiddling to work for me though (I have Points) and shimming/machining seems to be more of an occurrence than a Proform. Also Powermaster does have a (.1) better Review Star than Proform...
A Powermaster and the extra resistor wiring I would need for a 9012 to work for me is ~ $100 more than the (hopefully) a plug and play Proform.
*Side note...that will upset some, I do have a 50lbs working 1968 Delco-Remy Starter with a new Duralast solenoid on it, but Man it's Killer installing it!
I'm headed to Summit to buy the Proform right now, Hopefully I'm not back here in 3 months complaining that it pooped out on me......
Old 03-10-2026, 07:30 PM   #10
Shifty One
Shifty One's Avatar
Originally Posted by Loose Screw View Post
Thanks My Brothers!
Heres some pix...
You can use the Chevrolet, for example, a 1998 C1500 starter, and get the same one, just add Dorman bolts p/n# 678-107.
Old 03-10-2026, 08:05 PM   #11
Loose Screw
Yep, I see that, another guy in this thread mentioned that for a 6 cylinder S10, I think it's the same one or a variation. Delco on Rockauto about the same price OTD as a ProForm and the Delco is ~6 pounds heavier...
Old 03-11-2026, 12:20 AM   #12
Loose Screw
Ok, so I ordered the Proform Mini Starter I pictured above.
I haven't really dove into this yet, thought I'd ask Here First...
What About The Starters Front Hold Down Bracket?
My Truck didn't have one when I got it, the mounting hole on my small block and a pieces of all thread off the original starter are there but no bracket...
I will be checking into that.....
Old 03-11-2026, 12:43 AM   #13
Loose Screw
Holy Moly...Summit, Speedway and A1 are selling those Starter Brackets for $70+!
I ordered 1 from AutoZone $13.51 OTD....Hope I get it!
*Edit: ....Hope it fits... but yeah, I'll probably end up having to Blacksmith me a bracket out on the sidewalk with a piece of angle iron, hammer and a Benzomatic with my luck anyway.....
Old 03-11-2026, 03:46 AM   #14
jjzepplin
jjzepplin's Avatar
My mini starter failed after about 15 years. The front drive wore out. It is a 10:1 compression engine. I bought a stock unit and it is working fine for about 8 years. I made it so that both batteries are hooked up to it when I start and then they separate again. I found a drive for the mini and replaced it and now it sits in a box somewhere. It not the type you picture above. It's a CVS or something. The drive just hangs out with no support on the other side. It's a clockable unit. Worked awesome til it didn't.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-11-2026, 06:06 AM   #15
mkmc69
mkmc69's Avatar
What is the part number for the bracket, if you don't mind?
mkmc69 is online now   Reply With Quote
Old 03-11-2026, 09:46 AM   #16
connorm
connorm's Avatar
They are different starters. I know a guy that only uses the 6 cylinder S10's over C1500's. I believe the S10 starter is smaller, has more torque, and it's maybe cheaper. I think it depends on the source. I personally will be doing an S10 starter when I have to replace my GMC's starter
1970 C/2500 Ol' Green https://67-72chevytrucks.com/vboard/...d.php?t=668003
2016 GMC Sierra K1500
1953 Mercury 2 Door Sedan https://67-72chevytrucks.com/vboard/...17#post9381817
connorm is offline   Reply With Quote
Old 03-11-2026, 10:27 AM   #17
KQQL IT
At the body shop.
KQQL IT's Avatar
2 sbc
2 454
All same
Ac delco
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 03-11-2026, 10:56 AM   #18
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
So far great. If I ever see another 10K pound starter again it will be too soon.
ACDelco #337-1022, GM #88877121
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-11-2026, 11:05 AM   #19
Loose Screw
Here put this into Google and shop around you'll see what I was talking about.
GM Genuine Parts Starter Bracket 03965589
All the "Build" videos I've seen online never show *this Bracket", I just happened across it in a Venders Parts Drawing.
Old 03-11-2026, 11:15 AM   #20
Loose Screw
Beauty, but I got Points...
Aaaand do you have the front hold down bracket on yours?
I better show what I'm talking about...
Old 03-11-2026, 11:24 AM   #21
Loose Screw
Yes, and I was told about some "points delete" gizmo that'll fit inside my 1968 distributer. I haven't shopped for it yet, if it even exists. And I know, I know I need to study HEI!
Old 03-11-2026, 12:14 PM   #22
Steeveedee
Steeveedee's Avatar
I had a '69 Nova (wish I still did, nowadays) with 250 CI six and ran points. I got as much as 33k miles out of a tune up. Almost all highway miles.
~Steven
Simi Valley, CA
Old 03-11-2026, 01:12 PM   #23
MikeB
MikeB's Avatar
I highly recommend a 1990s AC Delco permanent magnet starter. All kinds of room around the starter. And the engine spins over faster than my old full-size starter.
It's an AC Delco Gold part to fit 350s (and maybe other engines) with 168-tooth flexplate/flywheel. Everything about mine looked brand new, as you can see in the photo.
AC Delco #336-1910A
GM #88864291
I paid $102 for it in 2022 on Amazon. Unfortunately it's now $148, but that's with free Prime delivery. Wish my income would have gone up 45% in the last 4 years!
Instructions are very informative. They call out specific bolt P/Ns you will need to use, which are knurled above the threads, unlike standard bolts.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 03-11-2026, 02:01 PM   #24
Loose Screw
AC Delco #336-1910A
GM #88864291
By the time you changed to that smaller starter had you ditched your points?
Old 03-11-2026, 02:07 PM   #25
MikeB
MikeB's Avatar
Yes. Good point though. No pun intended!
Mike
