Old 03-17-2026, 02:34 PM   #1
IT Cowboy
IT Cowboy's Avatar
Are steel valve covers prone to leaks or a myth?
Are the steel OEM valve covers as prone to leaks as usually mentioned or is it a myth from mostly wrong installation.
Are they really that touchy if they are straight, and installed using a modern gasket and spreaders and not over torqued . Is it better to use the gaskets with the metal inserts better or is a thinner old school gasket better so they would be more flat when tightened down.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
