Old 03-21-2026, 02:02 PM   #1
IT Cowboy
IT Cowboy's Avatar
How to install valve covers - sealant or none
Installing new valve covers...
Should I use gaskets and attach them to the covers first using sealant
use no sealant and just a gasket
use sealant only
I have heard of using the FIPG 103 alone with good results but I dont want any excess to break off inside the cover and cause issues.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
