How to clean exterior finish that’s been sitting in the sun for years
Hi guys, when I bought my 69, it had been sitting outside in the sun for years.
Overall the paint looks pretty decent but it’s got some oxidation and pretty rough to the touch. I’d like to give it a thorough cleaning. What do you guys recommend? Clay bar? Polish and buffing wheel? Mineral cleaner? I’m all ears here. Also, on the passenger side, the steel bolts holding the side mirror rusted badly and this rust would drip down the door for god knows how many years in the rain. Any recommendations on how to get that stain off the door without harming the paint? I’ve included a pic below. You can see the stain on the passenger side door. Thank you!
1969 C10 Shortbed |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Re: How to clean exterior finish that’s been sitting in the sun for years
I'd use rubbing compound on the whole truck first, with polishing compound after that. That's way out of clay bar territory. Maybe that'll take the rust stain off? For the rust stain, I'd use WD-40 and 0000 steel wool if the compounds don't remove it.
![]() ![]() Join Date: Oct 2014
I'd start with a pressure wash first, then go to a hand wash. After that, you can evaluate the paint and go from there.
X2 ^^^. I`d probably use 3 or 4 cutting foam pads for the rubbing compound and a few for polishing. If you spread it out, you can wash the pads and just use 3 or 4. Just be careful not to go through the paint, take what the paint gives you. I would clay it after the rubbing compound, then polish. Then clean paint before you add any wax or sealant protection.
![]() Join Date: Jun 2022
Meguiar's #7 is a pretty good first step to clean and allegedly condition old paint. It's abrasive free
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
The Niner
![]() Join Date: Nov 2010
Google Comet & Scotchbrite or SOS pads.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
This! Especially if you are going with a patina-look.
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
All about them K’s
![]() Join Date: Jun 2014
This… with at least an orange hex logic pad, but I think I’d opt for a yellow on the first pass then move to orange and then to a white, while finishing with a black or red. And running finer product as you go thru the different pad grades, the last pass should be a wax or sealant depending on your preference. I would run a sealant myself.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
Comet and a car wash brush will get it pretty clean for a start..
Looks like a nice truck.
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
![]() Join Date: Feb 2022
What ever you decide, find a not so noticable section and test all the way to finished result.
All the above ideas are abrasive. The condition and thickness of this original paint is unknown. Be careful. The more aggressive the "cleaning product" the deeper the scratches will be in the remaining paint. Then you have to remove more paint to get those scratches out. By the time you get to your finished result you have elevated your risk of polishing off all the original paint. Given what appears to be the truck's originality, loosing the paint would be a shame. |
X2 ^^ Pick a test spot to figure out the best process, start to finish. Start less aggressive and go from there to get desired results. If you`re truly trying to save the paint, take your time and put in the effort. It`ll pay off in the end.
Thank you for all the replies
I will start with pressure wash, followed by hand wash, and then assess which option to pursue next. One more thing, my roof has a bit of surface rust that I’d like to address. What’s recommended there? Thank you.
1969 C10 Shortbed Last edited by Luke87gt; 03-26-2026 at 05:50 PM. |
#13 |
![]() Join Date: Jul 2007
Back in 1969 my buddy and I sat in line at the quarter car wash in Killen Tx and watched a couple of lifer staff sergeants scrub years of outdoor grime off a 55/56 Ford sedan with a couple of cans of Ajax. The car looked pretty decent when they rolled out of the carwash and luckily it was one of those lazy afternoons that we weren't in a hurry on and the only thing going on was washing my 69 Cutlass. A few days later we saw it and they had polished it and waxed it and it looked sharp as all get out.
The only thing that I am going to say about buffers and these old trucks is that you had better have plenty of skill and finesse with with a buffer before you try it on the old original paint on one of these.
#14 | |
https://www.summitracing.com/parts/por-7424xp The pro type 7-9" orbital polishers with the wool pads are definitely going to have a learning curve
#15 |
I used to hand-ball the heavy grit cleaners. No chance for burn-through, but pretty time-consuming. Nowadays, I have to pay people to do it.
#16 | |
https://www.detailking.com/products/...isher-fc3321-z OP I would start out by cleaning the paint several times by washing . Test a small area with different degrees of aggressive paint correction products . Always try the least aggressive first then work up to what works on your paint . You might even try 2000 to 3000 sand paper to start . I did this on my 68
#17 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 03-28-2026 at 01:42 PM. |
#18 | |
![]() Join Date: Dec 2009
This Iron remover help some. Link: https://shop.advanceautoparts.com/p/...%20Restoration
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#19 |
Regular toilet bowl cleaner works great for rust stains also..
#20 |
Moderator
![]() Join Date: Dec 2012
Ideal candidate for the Comet wash. Then, cutting/buffing/polish/wax. Or cut/wax, lol
#21 |
Can someone link me to this comet wash?
1969 C10 Shortbed |
#22 |
Comet cleanser, but I bet Bon Ami would work just as well, and has no chlorine in it. YMMV
#23 |
Oooh, you guys are actually referring to the powder in the green can that I use to clean my toilets? Really? :-)
1969 C10 Shortbed |
#24 |
Not I.
#25 |
Active Member
![]() Join Date: Feb 2015
My 67 C30 wore the original orange/red color when I got it. I'd bet it was last hand washed 40 years ago.
I used a good detergent and Scotchbrite pads to scrub it down. Had a nice satin look to it when dried. Next, I used a regular auto paste wax and rubbed it in. It seemed to suck in the wax so I did it a second time and that gave me the look I was after. It didn't really shine like a fresh waxed new car. It has a flat/satin finish that screamed original paint. |
| Bookmarks |
