Old 03-27-2026, 06:40 PM   #1
mike16
Engine block drain plug and pet cock install
What size Allen wrench fits these drain plugs in the side of my 72 307?
I want to install pet cock style drain valves in this location.
What size threads or a part number for the correct drain valve?
Any advice on removing these plugs while the engines in the truck.
Thanks all!!
mike16 is offline   Reply With Quote
Old 03-27-2026, 06:57 PM   #2
Shifty One
Shifty One's Avatar
Re: Engine block drain plug and pet cock install
IIRC, they take a 1/4" hex. As far as pulling them, I'd soak them with your favorite sauce for a while before assaulting them. I like to rap on them a bit with a plastic-faced hammer if they give you problems. Might want to have a small butane torch available on call, just in case.
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 03-28-2026, 10:30 AM   #3
leegreen
The thread is 1/4 NPT so that should be 1/4 hex socket.
Use a good quality tool, it may be very tight. Breaker bar tight, the thread size is close to 1/2" bolt
leegreen is offline   Reply With Quote
