Old 03-28-2026, 10:21 PM   #1
jlmerie
jlmerie's Avatar
What are these brackets?
I am going through boxes and finding stuff I had forgotten was here. I found a small bag of brackets. I thought they were for the mid 80's Silverado grilles, but I cant make heads or tails of them. Maybe they are for something completely different. Any help is appreciated.
James
jlmerie is offline   Reply With Quote
Old 03-30-2026, 12:25 PM   #2
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: What are these brackets?
maybe the ribbon trim on the back of the cab??? or trim along the sides??? HHMhhhMmm..
rodstored-72 is offline   Reply With Quote
Old 03-30-2026, 08:09 PM   #3
Pontiac1976
Pontiac1976's Avatar
Are they for the Avatar Truck PIC you're using. Then might be front chrome trim on the grille or other chrome trim somewhere on the truck.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-30-2026, 08:57 PM   #4
jlmerie
jlmerie's Avatar
Thanks, I am familiar with the trim you reference and this does not match. I appreciate you sharing your thoughts.
James
Old 03-30-2026, 08:59 PM   #5
jlmerie
jlmerie's Avatar
No, they are not for that truck. It is a 1978. I have some feeling these are for the Silverado trucks of the mid 1980's. Thanks for sharing!
James
