Old Yesterday, 01:50 PM   #1
71C10SWB
71C10SWB's Avatar
Silversport TKX Hydraulic Clutch bleeding
Hey guys, I finished installing a full SilverSport Transmissions TKX kit into my 71 C10 over the winter and I love the transmission.
My problem is the hydraulic clutch set up. I have bled it the way they said to, I've used vacuum pumps and pressure bleeders, I've tried every trick in the book out side of pulling the slave cylinder and bleeding it outside the truck...really trying to avoid that.
I've talked to their tech folks but I just can't seem to get this thing right.
I have decent pedal and I'm not having any trouble getting it into gear while its running and clutch is depressed. It just feels like its not engaging until the last 25% of the pedal travel.
I would like to get what I have working before replacing anything. If I do have to do something different, I've looked at the kit that another member sells on here.
Any other suggestions or any other members with this set up?
I've replaced hydraulic throw out bearings and master cylinders on a lot of different vehicles and I know that some are better than others. (some really suck!)
Just getting frustrated and I want to get it right.
71C10SWB is offline   Reply With Quote
Old Yesterday, 03:53 PM   #2
LS short box
Re: Silversport TKX Hydraulic Clutch bleeding
On my LS swaps with a hydro throw out bearing I use a Mity Vac and install a SS bleed line into the throw out housing and suck the brake fluid out. Never had an issue.
I would contact Silver Sport and see what they say.
LS short box is offline   Reply With Quote
Old Yesterday, 04:13 PM   #3
71C10SWB
71C10SWB's Avatar
Yep, mine has a ss line and I have used the Mity-Vac. Like I said, I contacted them, did what they've said but still not overly happy with the results. I've got a could more things I need to try and then I may have to pull things apart.
Old Yesterday, 11:31 PM   #4
PbFut
Did you shim the TO bearing correctly to the slave to take up any slop. If not, no amount of bleeding will bring up the engagement point. You are using travel of the slave to take up the slack. A remote bleader line makes things very easy. It's a simple braided line from the slave to a point easy to reach with a blender valve on the end of the line.
PbFut is offline   Reply With Quote
silver sport, silversport, tkx, transmission
