Garage Queen Material
serp. belt questions
would i still be able to convet my engine over to the serpentine belt system even though i dont have my A.I.R. pump?
also, my dad saw this http://cgi.ebay.com/ebaymotors/ws/eB...EBWA%3AIT&rd=1 and wanted to know if it would work |
That should work, it even has the A.I.R pump on it. Then look for the plastic fan from a 98 chevy truck
2004 Silverado Crewcab (Dark Spiral Gray) |
BAD BOW-Silverado XST
You can buy a pulley to replace the smog pump. Better yet get the bracket off a later model truck. 92-95. There are only two and costs less than $100 for both. I'm will be using some off a 94. The installation is a lot cleaner.
Slots go on anything!
Instead of the pulley, you can also use a shorter belt, and just not use the smog pump. It took a couple tries, but that is what I did to my 92 Z28, which uses the same setup as the one on Ebay.
1974 Jimmy- 5.3/4L80e/NP241 |
