Old 01-20-2004, 01:36 AM   #1
Lynx
Lynx's Avatar
Question ps return hose
Quick question: I replaced my power steering pressure hose on my 83 in the fall and like an idiot and keeping with my cheapo attitude i didnt replace the return hose at the same time... well now i gotta do it in the middle of winter! any way i said quick so here it is! : can i just go down to napa and get some hose cut? and if so what size, or do i need to order a special hose. Ive noticed in cataloges they have the return hose listed.....
Ben
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
Old 01-20-2004, 01:41 AM   #2
Mike76251
It doesn't have to handle the high pressure of the supply side but it must be compatable with PS fluid.
Mine has been on for years with only hose clamps (two on each end) and it doesn't leak.
If you don't get the right hose (compatable with PS fluid) you can be in for a big problem when the hose comes apart on the inside.
Mike76251 is offline   Reply With Quote
Old 01-20-2004, 01:52 AM   #3
shavedchevy
shavedchevy's Avatar
ain't that the way things go. they'll work fine when it's nice out, and then alll of a sudden when it -30C everything that can go wrong does.
Dennis
shavedchevy is offline   Reply With Quote
Old 01-20-2004, 01:58 AM   #4
Lynx
Lynx's Avatar
Yeah its a piss off, but im ok with it ive been wanting an excuse to spend some time with the truck, i just hope it can warm up just a wee bit.
So i have to get a special hose that is compatable with power steering fluid?
Ben
Old 01-20-2004, 01:59 AM   #5
shavedchevy
yeah, might as well so it doesn't happen again.
Dennis
Old 01-20-2004, 02:03 AM   #6
Lynx
Lynx's Avatar
sounds good ill pick it up tommorow!
Ben
