Old 01-20-2004, 07:32 AM   #1
71-longbed
Its Magically Delicious
71-longbed's Avatar
seatbelts hangin loose
ok ... im tired of my selt belts getting caught in the doors ... mostly by my passengers ... both sides dont want to retract anymore ... is there something i can check or replace to get these things back to semi-normal again .... any tips or suggests would be great
what have you guys done about this problem ??
thanks
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 01-20-2004, 08:27 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You gotta love it when the male part of the buckle lays in the door jamb and stops the door from latching. (Can you tell I've been there?)
I simply replaced mine, but I had a real nice parts truck at my disposal.
Old 01-20-2004, 09:01 AM   #3
JimKshortstep4x4
Talking
Usually, lubing the retract mechanism works unless the spring is broke. What I do is remove the sheath and spray the roller with the belt full extended. Work it for a few minutes and if it does not retract properly, I adjust the spring by winding it up a few turns,
using the center pin. I use Aero Kroil but any light penetrant should work.
Jim
Old 01-20-2004, 04:50 PM   #4
71-longbed
71-longbed's Avatar
thanks for the tips jim ... whats Aero Kroil ..never heard of it
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 01-20-2004, 10:00 PM   #5
JimKshortstep4x4
Talking
It is a made in Tennesee penetrant that has been around for a long time. It works very well as a penetrant and as a light lube. I like it because it is not flammable and a can lasts a long time.
If you are interested I can PM you the address as it is sold direct.
Jim
