01-20-2004, 01:12 PM | #1 |
Post Whore
Damaged fan blade - repair or replace
The cooling fan on the engine I am going to use in my 69 was damaged slightly from a frontend impact. Appears one blade is bent slightly. No visible damage when you look at the blades but if you lay it flat you can tell one blade is bent.
Any thoughts on whether it is a bad idea to try to bend the blade or is it smarter to just replace it. It is a 5 blade fan off a 1989 454.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
01-20-2004, 01:26 PM | #2 |
Roadtrip!
I wouldn't take a chance on it. After all the time and $ spent, Why take a chance on something that may wipe out bearings or worse.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
01-20-2004, 03:14 PM | #3 |
I say replace too. Cheap insurance. If its out of balance it could mess stuff up, and if it has a crack that you can't see and a blade comes off will end up costing way more than just a new fan.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-20-2004, 04:14 PM | #4 |
Wiseass secured himself a BAN
Yep replace it. The bearing are going to go out in nothing flat. You should see what kind of damage a fan blade can do to a radiator. Not pretty.
01-20-2004, 04:43 PM | #5 |
Replace it.
01-20-2004, 05:28 PM | #6 |
computer illiterate
I AGREE TOTALLY! REPLACE IT.
72 2wd blazer 72 swb 4x4 |
01-20-2004, 05:37 PM | #7 |
Replace it. Just imagine the damage that could happen if it came off going down the road.
01-20-2004, 05:44 PM | #8 |
Post Whore
Thanks, advice will be taken. I didn't figure it was wise to use but wanted to get the general thoughts of you all.
01-20-2004, 05:50 PM | #9 |
Jack, I totally have to disagree with the rest of these guys, you have a chance to do something great here…
Remove the blade all together. That will still leave 4 blades more than enough to get the job done. Who cares about the vibration? Tell people it’s a blower. When some one looks under the hood tell them, “when I get around to fix’n that welder I’ll tack her back on.” But you got to keep a straight face, then buy some Coors Light with the money you save and sit on the porch and look at your neighbor’s funny with one boot on and one halfway off… Ever one will say, "Looky there kids, That's Crazy Yukon Jack" ... Chevy Pete.
1968 Chevy - 3/4 Ton - 4X4 - Longbed - 383ci - TH350 - NP205 Building the motor, painting the engine bay, rewireing everything... (775)-527-1199 / ryanspeterson@msn.com |
01-20-2004, 06:01 PM | #10 |
Try spinnin 4 rear tars
I don't know about that ChevyPete, he's
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
01-20-2004, 09:13 PM | #11 |
Workers compensation in BC sent out an advisory lately regarding a mechanic who died when a weakened fan blade seperated, bounced of the underside of the hood and penetrated into his shoulder/neck area.
I'd always heard such a thing could happen but thought "what are the odds" Good policy is don't hang over the engine if any reving is going on, do it from the front seat not the linkage.
71 GMC 1500 LWB |
01-20-2004, 09:43 PM | #12 |
there are times when you have to rev the motor while standing over it for example when you set the total timing
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
01-20-2004, 11:01 PM | #13 |
Old member
REPLACE IT!
REPLACE THE FAN. I have been there done that. You don't want to mess with it, it will cost you big time in the long run.
MY STORY: I was coming home one weekend when I herd a noise coming from the motor, it turned out the bearing had gone out on the water pump and the fan had hit the frame several times. It just got the tips of the blades. I replaced the water pump and straightened out the tips and went on my way. Two months later I have to replace the water pump again. I figured I just got a bad one. To make a long story short, I replaced the water pump three times in less than a year, and one A/C clutch. The last w/p I was replacing my dad happen to be at the house and I was telling him about all of this also, and as soon as he herd me say that I bent the blades back he said that's your problem it's out of balance. By the way my dad is retired from Chevorlet with 35 years and was the instructer at the training facility in Charlotte N.C. for about 6 years. He knows his stuff . Well I ordered a new fan and guess what, no more trouble, had the same pump now for over 5 years.
01-20-2004, 11:39 PM | #14 |
Designated Grumpy Old Man
If you want I can introduce to you a guy that got hit in the face with a fan blade that broke of and he can tell you how it happened. Oh yea, I forgot he can't talk anymore.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
01-21-2004, 12:43 AM | #15 |
My other Love
replace it, I had a fan blade go through the hood of my truck once, that wasn't cool
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
