Old 01-20-2004, 05:20 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Will 73 spindles fit a 72?
Will a set of 73 Spindles fit a 72 GMC that already has disc brakes? I heard that there is a diffrence in the lower ball joint is this true? Can I change the ball joints and make them work? Thanks, you guys are kewl!!!
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 01-21-2004, 12:43 AM   #2
grnddwn
belly dragger
grnddwn's Avatar
Change the upper ball joint and the outer tie rod end to 73 and up and they work just fine.
grnddwn is offline   Reply With Quote
Old 01-23-2004, 12:42 AM   #3
tucking70
how about a 70 with drums i know illhave to change the brake but thats what i want to do i just want to know if i can go with all 73 parts
tucking70 is offline   Reply With Quote
Old 01-23-2004, 01:48 AM   #4
grnddwn
belly dragger
grnddwn's Avatar
Yup just buy all 73 and up parts they're cheap too.
Old 01-23-2004, 10:26 AM   #5
72MARIO
72MARIO's Avatar
You also need a Tie Rod adjusting sleve CPP sell's it. The outer tie rod for a 73 is bigger than the 72 inner. Other than that it will work awesome. I did it. Also you can use 73-87 flex lines too. Oh and you use a 67-70 outer tie rod on the inner. No that's not a TyPO. I am serious.
Any other questions just ask.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-30-2004, 05:03 PM   #6
6T9GMC
6T9GMC's Avatar
Question ADD A QUESTION?
73-87 are they all the same? I have spindles, calipers, and everything off a 78. Would it all fit if I used the newer upper & lower ball joints, and just change the outer tie rod ends?
My truck is a 1969 w/drums.
thanks
6T9GMC is offline   Reply With Quote
Old 02-12-2004, 11:41 PM   #7
Orange70chevy
Orange70chevy's Avatar
My truck is a 70 and I used the spindles and calipers Etc.. off a 78 just change out the upper and lower ball joint. I used the tie rods and centerlink off of the 78 it fits on the stering box perfectly. Remember to install a proportioning valve I used one off a 71 or 72.
Orange70chevy is offline   Reply With Quote
