Old 01-20-2004, 06:12 PM   #1
crackajacka
Stylin
crackajacka's Avatar
timing question
where exactly is the tab to tell what the timeing is at? either i dont have one installed or im overlooking it. i have 2 different ones that went with the plug wire looms. if i dont have one on it which one should i use and where should i mount it? also what gap are yall running on yalls spark plugs?
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 01-20-2004, 07:42 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
you should see the timing tab at the bottom of the motor riding off the lower pulley if ya look straigtht down from ontop of the motor there should be sone kind of tab there also on HEI its .045 on regular its .035 gap
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-20-2004, 10:12 PM   #3
Jason Spears
Jason Spears's Avatar
The timing tab is on the front cover of the engine. Look straight down behind your water pump and you will see it. This is where you point your timing light. There is a line on the harmonic balancer that will line up with the notches on the tab when the timing light flashes.
I always use the manufacturer's recommended spark plug gap. Unless you're running something wild you won't gain any performance by varying the gap.
Hope this info helps.
Jason Spears is offline   Reply With Quote
Old 01-21-2004, 12:23 AM   #4
84Stepper
84Stepper's Avatar
Hey old Rusty...I have a MSD HEI, and believe my gap is .035. Runs pretty good, should I consider .045? and why? Thanks.
84 Chevy Stepside, 350, TH350, 268h
Comp cam, Hooker headers, MSD
Pro Billet, Edelbrock Performer manifold
and 1604 carb, 40 Series Flowmasters
dumped, and Western Chassis 3/5 drop w/ c notch. New 3:73 Eaton Posi
84Stepper is offline   Reply With Quote
Old 01-21-2004, 02:10 AM   #5
crackajacka
Stylin
i changed the gap to .045, and changed my dist. vaccum advance to the timed port on the carb, and ive got more get up n go
