Post Whore
![]() Join Date: Feb 2000
Hydraulic clutch and Hydroboost install
Been getting work done on the truck slowly. Got the hydraulic clutch installation basically done last night. Buddy cut me the reinforcement for my firewall with his plasma cutter. Nice piece of equipment.
Another buddy made me the metal shim you see that positions the hydraulic cylinder correctly so the push rod will attach to the clutch pedal. Got the cylinder mounted on the firewall, threaded the push rod and am using a 5/16" Heim joint to attach the rod to the clutch pedal. Cycles freely and the rod will push in as far as needed. Might have to make a stop to limit the clutch pedal. Here are some pics.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 01-16-2007 at 03:47 PM. |
Post Whore
Next pic
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Designated A-hole!
Looks good. Ya'll do good work.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Broke
Hydraulic clutch, thats the way to go! Good work.
72CheyenneSuper1ton4x4BigBlock |
Born To Lose Club
![]() Join Date: Feb 2003
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
This may be a dumb question. So what's the advantage to using a Hydraulic Clutch setup?
Brian Smith ![]() 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
Merciless Butcher
Very nice looking. It's a major pita setting it up. I did it one time in a '71. Your setup looks way better than mine did. If I was going to do it again, McCloud makes a hydraulic throwout bearing setup that I would use. Good Job!!!
Your Bought And Sold....I Got Your Soul! |
Post Whore
The advantage for me using this clutch is having swapped in a big block in my 4x4 and using headers, I would have had to make custom linkage to get a manual clutch working. Still had to do some modifications to make this work but I think this was the easier way. Plus I had all the parts available off the donor vehicle.
It must soften up the cluch pedal too! NO?
I don't know about yours, but a long trip 1000miles and my knee is done for 2 weeks! adjusting rods also sucks!! How much is that set up!
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Looks good.Nice to have friends...eh!:p
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
#10 | |
Born To Lose Club
Post Whore
Made a change last night to using a clevis rod end rather than the Heim joint. Mainly did it cause I got that setup for the brake pedal booster, but I think with two attachment points on each side of the pedal this will be stronger.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 06-24-2010 at 09:34 AM. |
Post Whore
Next I got the hydroboost brake cylinder hung on the firewall. I had to knock the two lower stud bolts off the pedal assembly and drill a couple holes but no biggie. Probably have to modify how the steering column attaches to the firewall as the brake booster bracket covers one of the attachment holes.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 01-16-2007 at 03:35 PM. |
#13 |
Post Whore
Mounted the rod to the brake pedal same as with the clutch. The brake booster rod is 3/8" while the hydraulic clutch rod is 5/16". I cut off the end of the brake booster push rod, threaded it and got it connected to the brake pedal using another clevis rod end.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 01-16-2007 at 03:36 PM. |
#14 |
huh ???
Hey Yukon, what are you using for a slave cylinder???
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
#15 |
Post Whore
The whole setup (brake booster and hydraulic clutch) came from a donor 1989 1 Ton crew cab.
#16 |
Broke
Hey Yukon, this is off the subject but, what kind of headers are you running on that 454?
#17 |
Post Whore
For exhaust I bought Dynomax Cerama-Coated headers. As 67-72 4x4's didn't come with big blocks, I ordered the big block headers for 67-87 BBC 2wd, part no. 86003. Had to massage the engine tower and frame a little, but the headers fit very well now and the collectors should be fine with the transfer case.
#18 |
Thats Pretty Slick Install there.
I have a 68 Im about to have to fab up a hydralic clutch setup I was considering useing a master cylinder off of an 86-87 One Ton Mainly cause its cheap and it mounts flat Was the rod proper lenght or close to it for your app? I might look into the newer model If the 87 Gives Me any Problems. |
#19 |
Post Whore
I had to cut some of the length off the rod, thread it and put the end on that you see. Just make sure you take time and make sure the push rod will function correctly. I had to lower the hydraulic cylinder to get it in the right position.
#20 |
I was going to take the straitedge off my sqaure and put it on the side of the pedel and mark me a hole that would be pretty even with the area where the rod will hook Thats basically all i lack to have my T5 conversion complete.
#21 |
Looks great Mark! Some first class fab work. Can't wait to see some finished pics.
