01-21-2004, 02:24 AM | #1 |
What is this?
Can anyone tell me what this is?
Thanks |
01-21-2004, 02:28 AM | #2 |
unless I don't understand your picture that is the passenger side front cab mount (bushings)
01-21-2004, 02:31 AM | #3 |
cab mount
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
01-21-2004, 02:32 AM | #4 |
WHYBYNU when old will do
Looks like a cab mount with old dried out bushings...
John
71 Cheyenne super 2 tone green and white ZZ6 - Th350 4/6 drop 20x8.5 / 20x10 Billet Specialties |
01-21-2004, 02:33 AM | #5 |
Yep looks like the cab cushion as they are called in LMC cataloge.
01-21-2004, 02:38 AM | #6 |
hey, that looks just like mine! oh yeah, except its not covered in road salt golly gee whiz I love Ohio!
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
01-21-2004, 02:39 AM | #7 |
Thats what I thought they were. Well time to replace them. Do I have to take off the cab to do this?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
01-21-2004, 02:47 AM | #8 |
BlahBlahBlah
i already had my cab off when i replaced mine but i think all you have to do is pull the bolts and jack the cab up just enough to slide in the new ones.
01-21-2004, 02:58 AM | #9 |
Make sure you unbolt the front radiator mounts and bushings and also take off your fan shroud.( Ibroke my shroud jacking mine up) MAKE SURe TO LEAVE YOUR DOORS CLOSED!!!!!!! You can twist the cab if you open the doors while you have the cab jacked up with all the stuff still inside.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
01-21-2004, 03:17 AM | #10 |
This, is my BOOMSTICK!
Yup, I agree with everybody above.
Larry Got rid of my projects for now. 1980 Jeep CJ7 1998 Nissan Sentra (my car) 2001 Toyota Sienna (wife's, of course) |
01-21-2004, 03:27 AM | #11 |
Wow!!1 Ok thanks guys. I will get all four and put them in when I do the kick and rocker panels. Man that list just keeps getting longer.
01-21-2004, 09:30 AM | #12 |
Yeah, wait till you lift the cab off the frame to replace those bushings.
OOPS, looks like I need new cab mounts too. and while I'm under here I might as well................ Happens all the time
01-21-2004, 10:58 AM | #13 |
Watch out for your cornhole !
I always use OEM GM cab mount bushings. They seem much higher quality than the aftermarket set I saw.
