Old 01-21-2004, 02:36 AM   #1
1969 GMC
1969 GMC's Avatar
front wheel bearings
Hello all,
I asked this on the engine board but was hoping to get more responses. my trucks front axle is howling, and it is time for new bearings (i hope). i have a dana 44 front axle (and YES, that means my truck is a 4x4) with closed knuckles and drum brakes. what all do I need to do to replace the bearings? cableguy said I need to remove my drums, but what after that? will I need to take the axle knuckles off? my dad would normally help (mechanic) but he's never done them in a 4x4. thanks in advance.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-21-2004, 07:12 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I repacked mine not too long ago. You'll need to take the locking hub off. then remove the snap ring on the end of the stub shaft. Oh yea if you have the large external locking hubs, the locking hub comes of and then a spacer with possibly a metal gasket. But any way take those off as well as the tire and drum (understood I know). Next the (it's called the hub) hub is removed by taking the two nuts off the spindle. These require a special four prong socket that is about 3" in diameter purchase at local parts house for about 8 bucks or you can use screw drivers (not recommended). Becarefull as now the hub can come out as well as the bearings. At this time you can replace the inner seal Which will have to be removed to get the inner bearing and race out. the outer bearing will come loose when the two nuts are removed. I'll check my repair manual after I get home for the tourque settings and I'll add to the post. Any questions? Now do it!
You will not need to remove the steering knuckles. If you need to replace the ball joints you would be able to remove the spindle know and then the axle shaft assembly.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-21-2004, 07:45 PM   #3
1969 GMC
1969 GMC's Avatar
thanks a ton Jim!
now I got somethin to do this weekend (if it only weren't so frickin cold!)
1969 GMC K2500
1996 Honda Accord
Old 01-21-2004, 09:45 PM   #4
71swb4x4
71swb4x4's Avatar
I am in the middle of the same project myself. Actually, I started it last Monday and then it got too cold for me so my truck has sat in the garage for over a week with only 2 tires
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-21-2004, 09:49 PM   #5
71swb4x4
71swb4x4's Avatar
Here are the instruction I ahve from my manual.
Adjust bearings by tightening nut snug while rotating drum. Loosen nut 1/8 turn and assemble lock-washer by loosening nut to nearest hole, then assemble outer nut. Tighten nut to 40 ft. lbs. minimum.
Shawn
Old 01-22-2004, 01:05 AM   #6
1969 GMC
1969 GMC's Avatar
thanks!!! I hope I get mine done a bit quicker than that, as its my daily driver. I think this extra cold weather we are having (-11 low last night) isn't helping the problem. about how much are these? around $10/each for a grand total of $40? thanks!
1969 GMC K2500
1996 Honda Accord
