Back from the Dead
67-72 Step Notch
I'm looking for any info relating to a Step Notch for the 67-72 Coil-Spring frames? I know Turners sells one, but how much? Also, would it be possible to modify a Universal 8-piece Notch to work? Any info, pictures or experiences with this would be great.
Thanks in advance! Kenny
The only Carb that matters to me is the one under my hood! Salem, Oregon |
#2 | |
Trucker.
Re: 67-72 Step Notch
///Relaxed Atmosphere
my 64 step notch
Here isa pic of my 64 step notch I did. I bent an Ekstenive Metal Works 99 model chevy step notch kit on a hydralic metal worker and made it work on the sides, and then just capped the top and bottom of the step notch with plates as your would normally do on a step notch.
Jeff |
Back from the Dead
98L150- That is sweet, too bad I dont have the tools to reproduce that...wanna make me one?
![]() Thanks, Kenny
Progress = 0%
Keep in mind that you're going to have to raise your bed floor or cut a hole in it for notch/pumpkin clearance if you install that large of a notch. Cutting a hole in the bed floor is tacky IMO.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
Back from the Dead
Your right slammed67, I would proabbly look into raising the bed floor...however, I'm not familiar about how its done?
Kenny
i, personally, would raise the bed floor. a whole lot cleaner than cutting a big tacky hole and you cant use teh bed after you cut that hole either
70 longbed 496/th400/Ford 9" |
cutting up the bed floor
I guess it really depends if you ever want to haul anything in your truck when you get done. I have a bed cover on mine so you can't see it anyway and my dually carries loads much better anyway.
It'd be alot cooler if you did
Turners and KP Components both make a 67-72 specific notch. Both are pretty pricey.
Back from the Dead
Does anyone have any prices or pictures of step notches/kits? Thanks for all the information and input.
#11 | |
