Junior Member
rear end swap
I want to change my 67 coil rear end to a 5lug. My question is what other rears will fits? Can I put a newer rear in and change the axle saddles? If I go to the junk yard what width axle am I looking for or what year am I looking for ? Forgot to mention it is a 2wd and I would like a 3:73 rear.
Thanks for the help, Pete |
Designated A-hole!
A rear end from a 71 or 72 with coil spring should bolt right in and give you your 5 lugs. 73 and up are all set up for leaf springs.
Somewhere there is discussion on using 71 and up axles in your rear, but they are 3/4" wider than your present axles and you would have to make a spacer to use them.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
I would try to find a 71 or 72 truck with the coil springs. It would be a direct bolt in and I think allot of the 6cyl and some of the v8 trucks had 3.73's.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
