Old 01-21-2004, 11:13 AM   #1
72gmcshorty
72gmcshorty's Avatar
Kinda OT...Oil covered spark plug....
I changed the spark plugs on my car (86 firebird) and found one heavily covered in oil (around the threads and towards the spark end of the plug). I didn't see any oil on the outside of the plug hole. All three spark plugs on the drivers side were also burnt at the bottom of the ceramic part of the plug. Is there a problem here? Maybe time for a rebuilt head? The car has 228,000kms
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 01-21-2004, 11:44 AM   #2
cdowns
cdowns's Avatar
as long as it's running i wouldn't mess with it putting a new/rebuilt head on a high milage engine just seems to cause more problems than it's worth sealing up the top end just increases blowby on the cylinder to piston ring seal
Old 01-21-2004, 04:09 PM   #3
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Sounds to me that the spark plug with oil on it is not firing. There should not be liquid oil, but burnt oil.
67Fleetsidedream is offline   Reply With Quote
Old 01-21-2004, 04:50 PM   #4
nightmare
nightmare's Avatar
like 67Fleetsidedream said, it should be burnt oil. if it was idling rough, running rough, getting poor gas mileage, there was a possibility that the plug wire came off. is that why you were changing plugs?
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is online now   Reply With Quote
